building libraries
Wed May 31 17:08:50 CDT 2006
On Wed, 31 May 2006, Matt Funk wrote:
> Hi,
> i need to build PETsC on s sycld machine. Basically i need to have MPI support
> in PetsC but i need to switch from using mpicc to gcc.
why use gcc over mpicc? [mpicc should be internally using gcc so it
should satisfy the gcc requiremetn]
> I was wondering if someone could point to how i can do that. (Is there an
> option that i overlooked?)
Look at 'mpicc -show' to determine the include & library options
required to use this MPI - and then configure PETSc with:
--with-cc=gcc --with-fc=g77 --with-mpi-include=/foo/bar/mpi/include
--with-mpi-lib=[/foo/bar/mpi/lib/libmpi.a,anotherlib.a,anotherlib.a]
'mpicc -show' should give the path to libmpi.a and its dependendent libs.
Satish
