building libraries
Wed May 31 17:08:44 CDT 2006
You can have PETSc install MPI using --download-mpich. You can make
sure that it does not use mpicc using --with-mpi-compilers=0.
   Matt
On 5/31/06, Matt Funk <mafunk at nmsu.edu> wrote:
> Hi,
> i need to build PETsC on s sycld machine. Basically i need to have MPI
> support
> in PetsC but i need to switch from using mpicc to gcc.
> I was wondering if someone could point to how i can do that. (Is there an
> option that i overlooked?)
> thanks
> mat
"Failure has a thousand explanations. Success doesn't need one" -- Sir Alec
Guiness
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20060531/888037e2/attachment.htm>
