symmetric matrices
Randall Mackie randy at geosystem.us
Mon May 22 10:59:47 CDT 2006
Hi Matt,
Thanks, that fixed the compilation problem, but then the program just seemed to
hang at the place where it was creating/assembling the matrix.
Maybe I do not understand how to set bs, the block size for the call
to MatCreateMPISBAIJ, any advice?
Are symmetric MPI BAIJ matrices my only choice? Is there not a symmetric MPIAIJ
matrix format?
Thanks, Randy
Matthew Knepley wrote:
> The Fortran interface fell behind. I will fix it in dev, but for now you can
> just use the value, 91. You can also use the command line option.
> Thanks,
>    Matt
> On 5/22/06, *Randall Mackie* <randy at geosystem.us
> <mailto:randy at geosystem.us>> wrote:
>     I'm trying to modify my code to take advantage of the fact that my
>     system matrix
>     is symmetric.
>     It seemed from reading the manual pages that I could call
>     MatCreateMPISBAIJ
>     to create a symmetric data matrix.
>     However, when I tried this, I got the error:
>     [1]PETSC ERROR: Lower triangular value cannot be set for sbaij
>     format. Ignoring these value
>     s, run with -mat_ignore_lower_triangular or call
>     MatSetOption(mat,MAT_IGNORE_LOWER_TRIANGUL
>     AR)!
>     So I tried including the line:
>            call MatSetOption(A,MAT_IGNORE_LOWER_TRIANGULAR,ierr)
>     But when I tried to compile the code, I then got this message:
>     fortcom: Error: csem3dfwd.F, line 771: This name does not have a
>     type, and must have an explicit type.   [MAT_IGNORE_LOWER_TRIANGULAR]
>     So, can anyone point me in the right direction for taking advantage
>     of the fact that
>     my matrices are symmetric? (they are actually complex symmetric, and
>     NOT Hermitian).
>     Thanks, Randy
>     Randall Mackie
>     GSY-USA, Inc.
>     PMB# 643
>     2261 Market St.,
>     San Francisco, CA 94114-1600
>     Tel (415) 469-8649
>     Fax (415) 469-5044
>     California Registered Geophysicist
>     License No. GP 1034
> "Failure has a thousand explanations. Success doesn't need one" -- Sir
> Alec Guiness
Randall Mackie
GSY-USA, Inc.
PMB# 643
2261 Market St.,
Tel (415) 469-8649
Fax (415) 469-5044
License No. GP 1034
