SBAIJ + hypre preconditioners does not work?
Tue May 16 07:30:03 CDT 2006
   I have not thought about hypre when only the upper-half of the
matrix is provided? Please tell me which of the 4 hypre preconditioners
support symmetric storage of the matrix and how I indicate that to
hypre that I am only providing half the matrix and I will add
support for you.
     Barry
On Tue, 16 May 2006, Sh.M wrote:
> Hi,
> So far I have been using AIJ to construct my matrices and this has been due
> to a legacy more than anything else.
> However now I do need the extra memory as my problems are getting bigger and
> bigger. So I have tried to use the
> SBAIJ matrix format with block size = 1. My matrices are read from a file
> and are symmetric but also "full" due to a legacy.
> However as I understand I can treat the full matrix as if it was just the
> upper triangle of it if I use command line
> -mat_ignore_lower_triangular.
> It has worked just fine when I for example use solver = CG and
> preconditioner = Jacobi.
> However I am getting some errors when using hypre preconditioners, for
> exampel BoomerAMG.
> I do know or atleast think by my own past experience with Hypre that
> symmetric sparse matrix support has not been trivial in Hypre eventhough the
> support was there. Can there be a case of PETSc + Hypre in combinaton simple
> not supporting the SBAIJ matrix format?
> I am getting this error message and I have tried with different matrices
> ranging from 54x54 to 5Mx5M and 1-32 CPUs.
> It crashes when it calls the solve function:
> [0]PETSC ERROR: MatGetRow_SeqSBAIJ() line 207 in
> src/mat/impls/sbaij/seq/sbaij.c
> [0]PETSC ERROR: No support for this operation for this object type!
> [0]PETSC ERROR: MatGetRow is not supported for SBAIJ matrix format. Getting
> the upper trian\
> gular part of row, run with -mat_getrow_uppertriangular, call
> MatSetOption(mat,MAT_GETROW_U\
> PPERTRIANGULAR) or MatGetRowUpperTriangular()!
> [0]PETSC ERROR: MatGetRow_MPISBAIJ() line 1056 in
> src/mat/impls/sbaij/mpi/mpisbaij.c
> [0]PETSC ERROR: MatGetRow() line 168 in src/mat/interface/matrix.c
> [0]PETSC ERROR: MatCholeskyCheckShift_inline() line 45 in
> src/mat/impls/hypre/mhyp.c
> [0]PETSC ERROR: PCSetUp_HYPRE() line 95 in src/ksp/pc/impls/hypre/hyppilut.c
> [0]PETSC ERROR: PCSetUp() line 798 in src/ksp/pc/interface/precon.c
> [0]PETSC ERROR: KSPSetUp() line 234 in src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: KSPSolve() line 334 in src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: User provided function() line 683 in petscSolver.c
> [2509 MPI_COMM_WORLD 0] Process exited without calling MPI_Finalize.
> Fatal error, aborting.
> With best regards, Shaman Mahmoudi
