Installation on windows
Thu May 11 20:28:08 CDT 2006
If you have problems installing PETSc - send us the relavent logfiles
to petsc-maint at mcs.anl.gov [the relavent log file here is
configure.log]
[assuming you don't need fortran & mpi] - you should be able to run
configure as:
./config/configure.py --with-cc='win32fe cl' --download-c-blas-lapack=1 --with-mpi=0
Satish
On Fri, 12 May 2006, Joel Schaerer wrote:
> Hi all,
> I've been using Petsc on linux successfully for some time. I'm now trying to
> port my code under windows, and it turns out, installing petsc on windows is
> not easy!
> If possible, I would like to use petsc with Visual Studio (my version is .NET
> 2003). I tried various config/configure.py options, but to no avail, petsc
> still uses gcc to compile itself...
> If that is not possible, is it possible to compile petsc with gcc and link the
> resulting libraries to Visual Studio compiled code? I've only been able to
> produce .a libraries, and if I understand well, I can't use .a libraries with
> visual studio.
> So: has anyone compiled petsc with the visual studio compilers? If yes, how
> (configure options, PETSC_ARCH used, etc.)? Also, is there any recent
> documentation about petsc on windows available? I've only been able to find
> outdated stuff...
> Thanks a lot!
> Joel Schaerer
