Two questions regarding SNES/KSP
Wed May 3 16:14:05 CDT 2006
On 5/3/06, Paul T. Bauman <pbauman at ices.utexas.edu> wrote:
> Hello,
> I'm a new PETSc user, so if the questions I ask are redundant, I
> sincerely apologize. I was, however, unavailable to find the following
> information in the manual pages.
> I have two questions.
> First: When using the SNES package, is the initial guess for the
> /iterative linear solver/ (e.g. conjugate gradient) 0.0 or is it
> something else (e.g. the current Newton solution)?
If you want that, you need to pull out the KSP from the SNES:
http://www-unix.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/SNES/SNESGetKSP.html
and then flip the flag in the KSP:
http://www-unix.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/KSP/KSPSetInitialGuessNonzero.html
Second: I see that PETSc checks the preconditioner matrix for positive
> definiteness, but does it check whether the current solution iterate is
> positive def. (i.e. if x_i is the current solution iterate and A is the
> current Jacobian matrix, does the algorithm check if (x_i)^T * A * (x_i)
> > 0)?
We cannot check that the preconditioner is positive definite. What we
actually
check it that the A-inner product calculated at each iteration is positive.
   Matt
Thanks so much for your help.
> Best Regards,
> Paul
"Failure has a thousand explanations. Success doesn't need one" -- Sir Alec
Guiness
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20060503/95d4d706/attachment.htm>
