Two questions regarding SNES/KSP
Paul T. Bauman pbauman at ices.utexas.edu
Wed May 3 16:02:57 CDT 2006
Hello,
I'm a new PETSc user, so if the questions I ask are redundant, I
sincerely apologize. I was, however, unavailable to find the following
information in the manual pages.
I have two questions.
First: When using the SNES package, is the initial guess for the
/iterative linear solver/ (e.g. conjugate gradient) 0.0 or is it
something else (e.g. the current Newton solution)?
Second: I see that PETSc checks the preconditioner matrix for positive
definiteness, but does it check whether the current solution iterate is
positive def. (i.e. if x_i is the current solution iterate and A is the
current Jacobian matrix, does the algorithm check if (x_i)^T * A * (x_i)
 > 0)?
Thanks so much for your help.
Best Regards,
Paul
