link with other libraries
Fri Jul 21 12:49:37 CDT 2006
The basic form of a PETSc makefile is as follows:
CFLAGS           =
FFLAGS           =
CPPFLAGS         =
FPPFLAGS         =
CLEANFILES       =
include ${PETSC_DIR}/bmake/common/base
ex1: ex1.o  chkopts
        -${CLINKER} -o ex1 ex1.o  ${PETSC_KSP_LIB}
        ${RM} ex1.o
If you wish to specify additonal libraries - you can do it as:
MY_INC          = -I/my/include
MY_LIB          = -L/my/lib -lmy
CFLAGS           =
FFLAGS           =
CPPFLAGS         = ${MY_INC}
FPPFLAGS         =
CLEANFILES       =
ex1: ex1.o  chkopts
        -${CLINKER} -o ex1 ex1.o  ${MY_LIB} ${PETSC_KSP_LIB}
        ${RM} ex1.o
Also - you should make sure this library is compiled with the same
compilers as PETSc is compiled with.
Satish
On Fri, 21 Jul 2006, jordi poblet wrote:
> Dear all,
> I would like to use PETSc within a finite element program (the main part is
> written in C++). Some classes should use PETSc routines and routines from
> other libraries. When compiling these classes, I have to include not only
> the header files from PETSc (which in the examples of a single C or C++
> files are included automatically with the sample makefiles provided in the
> manual) but also header files from the other used libraries. Finally, I
> would have also to link PETSc with other libraries at the same time.
> I have tried to construct a makefile including 'by hand' the PETSc headers
> but I have always problems. Could someone help me? Have you got makefile
> examples for this situation (or similar)?
> The compilation options for the PETSc library that I have employed are:
> ./config/configure.py --with-mpi=0 --with-clanguage=c++
> --with-scalar-type=complex
> tests and examples are passed correctly.
> I am running PETSc in linux machines.
> Thank you in advance,
> Jordi Poblet
