link with other libraries
jordi poblet jordi.poblet at gmail.com
Fri Jul 21 12:29:14 CDT 2006
Dear all,
I would like to use PETSc within a finite element program (the main part is
written in C++). Some classes should use PETSc routines and routines from
other libraries. When compiling these classes, I have to include not only
the header files from PETSc (which in the examples of a single C or C++
files are included automatically with the sample makefiles provided in the
manual) but also header files from the other used libraries. Finally, I
would have also to link PETSc with other libraries at the same time.
I have tried to construct a makefile including 'by hand' the PETSc headers
but I have always problems. Could someone help me? Have you got makefile
examples for this situation (or similar)?
The compilation options for the PETSc library that I have employed are:
./config/configure.py --with-mpi=0 --with-clanguage=c++
--with-scalar-type=complex
tests and examples are passed correctly.
I am running PETSc in linux machines.
Thank you in advance,
Jordi Poblet
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20060721/3cd36cb0/attachment.htm>
