Kubuntu Linux + PETSc Question
Fernando Campos asdfgf at ig.com.br
Tue Dec 19 10:39:44 CST 2006
I tried the option --with-debugging=0 and the performance of my application
in the sequential case decreased twice.
However, in Kumbuntu Linux it is less scalable than when using Rocks Cluster
system...
I am trying to find out why.. we gave up on Rocks due many problems.
Thanks Berend
Em (15:41:06), petsc-users at mcs.anl.gov escreveu:
>Hi Fernando,
>Have you tried configuring PETSc with the option
>--with-debugging=0
>That should generate optimized code.
>For using hypre, you can specify
>--download-hypre=yes
>Good luck,
>Berend.
>> Dear All,
>> I've found that, for my application, the PETSc that comes in Kubuntu
Linux
>> 64 is twice faster than the one we can get in the PETSc's site. I want to
>> use Hypre in my application, but I don't know how to use Hypre with the
>> already compiled PETSc library in Kubuntu. Can you give me some hints in
>> this task? Or maybe tell what should be reason for this difference in
>> performance.. maybe I need some flags in order to optimize PETSc
>downloaded
>> from the site?
>> Thank you.
>> Fernando Campos
