dmmg residuals and AMG
Wed Dec 13 11:11:56 CST 2006
 Nicolas,
On Wed, 13 Dec 2006, Nicolas Bathfield wrote:
> Dear Barry and Petsc users,
> I dig into the code to understand a bit better the output from the options
> -ksp_view -dmmg_ksp_monitor, but I am still confused (There is a printout
> of ksp/ksp/example/tutorial/ex29.c slightly modified below).
> -ksp_view gives:
>  MG: type is FULL, levels=3 cycles=1, pre-smooths=1, post-smooths=1;
> Does that really mean that I perform only 1 multigrid cycle? How can I
> control the number of cycles and the convergence criteria?
  The cycles 1 is INSIDE the information for the MG preconditioner. This means
that it is using 1 cycle of FULL mg as a PRECONDITIONER inside the outter (FLEXIBLE) GMRES.
If you do not want to use the fgmres acceleration then use -ksp_type richardson
-pc_mg_type multiplicative and it will do the usual v-cycle multigrid until
the ksp convergence tolerance (in your case reduction of residual norm by 1e5)
is achieved. To use a W cycle instead use -pc_mg_cycles 2. (I notice I don't have a
hook for using 2 V or W cycles as a preconditioner)
  So in short it is not doing 1 cycle and stopping it is using 1 cycle as
a preconditioner for a usual KSP method.
> What does the first index (0,1,2 or 3)in front of KSP residual represent?
   Sorry the formatting of the output got screwed up in that last release. Here is
what it should look like
[barry-smiths-computer:snes/examples/tutorials] bsmith% ./ex19 -dmmg_nlevels 3 -dmmg_ksp_monitor -dmmg_snes_monitor
lid velocity = 0.00591716, prandtl # = 1, grashof # = 1
    0 SNES Function norm 7.886953101160e-02
    0 KSP Residual norm 7.886953101160e-02           (initial residual of complete linear system)
        0 KSP Residual norm 2.578939596744e+00       (initial residual on level 1
        1 KSP Residual norm 8.580502942028e-01        residual after the pre smooth step on level 1
Note it does not print residuals on level 0 coarse grid because a direct LU solver is used (by default)
        0 KSP Residual norm 7.094309025479e-01        residual (after the coarse grid correction) on level 1
        1 KSP Residual norm 1.957760982966e-01        residual after post-smooth on level 1
      0 KSP Residual norm 2.075431534545e+00          initial residual on level 2
      1 KSP Residual norm 6.045540957388e-01          residual on level 2 after pre-smooth
        0 KSP Residual norm 6.594930640698e-01        initial residual on level 1 after restriction
        1 KSP Residual norm 1.873678881899e-01            level 1 after pre-smooth
        0 KSP Residual norm 3.181690759952e-01            level 1 after coarse grid correction
        1 KSP Residual norm 6.667286758128e-02            level 1 after post-smooth
      0 KSP Residual norm 1.612193634389e+00          level 2 after level 1 coarse correction
      1 KSP Residual norm 4.428777921897e-01          level 2 after post-smooth
    1 KSP Residual norm 2.757385168519e-02          (residual after one iteration of FGMRES on the entire system)
        0 KSP Residual norm 2.371988427435e+00
        1 KSP Residual norm 4.603841291940e-01
        0 KSP Residual norm 9.537098076551e-01
        1 KSP Residual norm 2.372055351128e-01
      0 KSP Residual norm 2.711798509188e+00
      1 KSP Residual norm 6.529602589787e-01
        0 KSP Residual norm 1.107566255572e+00
        1 KSP Residual norm 2.612091585278e-01
        0 KSP Residual norm 3.201409476039e-01
        1 KSP Residual norm 8.889931894491e-02
      0 KSP Residual norm 1.371722591156e+00
      1 KSP Residual norm 4.736289571173e-01
    2 KSP Residual norm 6.009911728204e-03
        0 KSP Residual norm 2.085355246785e+00
        1 KSP Residual norm 3.940644584596e-01
        0 KSP Residual norm 7.653134098239e-01
        1 KSP Residual norm 1.914404634341e-01
      0 KSP Residual norm 2.385479137738e+00
      1 KSP Residual norm 5.858823293243e-01
        0 KSP Residual norm 1.104077971916e+00
        1 KSP Residual norm 2.411330383552e-01
        0 KSP Residual norm 2.979088078743e-01
        1 KSP Residual norm 5.916390357483e-02
      0 KSP Residual norm 1.295627867427e+00
      1 KSP Residual norm 4.389707070240e-01
    3 KSP Residual norm 4.890428781555e-04
        0 KSP Residual norm 2.047523195596e+00
        1 KSP Residual norm 4.264677474628e-01
        0 KSP Residual norm 1.029983323961e+00
        1 KSP Residual norm 2.539427868572e-01
      0 KSP Residual norm 2.553639453818e+00
      1 KSP Residual norm 5.757990843674e-01
        0 KSP Residual norm 1.138585506415e+00
        1 KSP Residual norm 2.355704751953e-01
        0 KSP Residual norm 3.092827768419e-01
        1 KSP Residual norm 6.071447174488e-02
      0 KSP Residual norm 1.358066234308e+00
      1 KSP Residual norm 4.505697416265e-01
    4 KSP Residual norm 2.690993167559e-05
        0 KSP Residual norm 1.816339210351e+00
        1 KSP Residual norm 4.389412798513e-01
        0 KSP Residual norm 1.064334150012e+00
        1 KSP Residual norm 2.361933072662e-01
      0 KSP Residual norm 2.157389468526e+00
      1 KSP Residual norm 5.693236871123e-01
        0 KSP Residual norm 9.333422097061e-01
        1 KSP Residual norm 2.239182808762e-01
        0 KSP Residual norm 3.848098361086e-01
        1 KSP Residual norm 1.015246663039e-01
      0 KSP Residual norm 1.312503155715e+00
      1 KSP Residual norm 4.374736783054e-01
    5 KSP Residual norm 2.159855734129e-06
        0 KSP Residual norm 1.152776829315e+00
        1 KSP Residual norm 2.640188473397e-01
        0 KSP Residual norm 3.473379921732e-01
        1 KSP Residual norm 6.973067016139e-02
      0 KSP Residual norm 1.674499511581e+00
      1 KSP Residual norm 3.691885478016e-01
        0 KSP Residual norm 5.881350233350e-01
        1 KSP Residual norm 1.623887401757e-01
        0 KSP Residual norm 1.899371906578e-01
        1 KSP Residual norm 5.283607577248e-02
      0 KSP Residual norm 6.796871956361e-01
      1 KSP Residual norm 2.167234174310e-01
    6 KSP Residual norm 3.259317892179e-07
    1 SNES Function norm 7.468268333544e-06
> Thanks for your help.
> Best regards,
> Nicolas.
                 0 KSP Residual norm 1.421285957034e-02
>                1 KSP Residual norm 1.609288367464e-03
>              0 KSP Residual norm 2.699978999993e-01
>              1 KSP Residual norm 3.406567948849e-02
>       0 KSP Residual norm 2.101495954238e-02
>       1 KSP Residual norm 1.846013302069e-03
>       0 KSP Residual norm 8.326606206788e-04
>       1 KSP Residual norm 4.344001727320e-05
>       0 KSP Residual norm 1.577985727128e-02
>         1 KSP Residual norm 1.969730522207e-03
>       1 KSP Residual norm 2.116914409872e-02
>       0 KSP Residual norm 1.029801283683e-01
>       1 KSP Residual norm 7.594550723847e-03
>       0 KSP Residual norm 7.254183286194e-03
>       1 KSP Residual norm 6.000261158570e-04
>       0 KSP Residual norm 2.966998198077e-01
>       1 KSP Residual norm 5.201133083048e-02
>       0 KSP Residual norm 3.786415700595e-02
>       1 KSP Residual norm 3.901313528873e-03
>       0 KSP Residual norm 3.502275405186e-03
>       1 KSP Residual norm 2.803439371866e-04
>       0 KSP Residual norm 2.150042336470e-02
>       1 KSP Residual norm 3.280472811048e-03
>       2 KSP Residual norm 1.206584038156e-04
>       0 KSP Residual norm 1.010495676349e-01
>       1 KSP Residual norm 5.373641377818e-03
>       0 KSP Residual norm 3.177241089754e-03
>       1 KSP Residual norm 2.956553309307e-04
>       0 KSP Residual norm 2.439978649540e-01
>       1 KSP Residual norm 2.775398636052e-02
>       0 KSP Residual norm 2.197619585488e-02
>       1 KSP Residual norm 1.465557162804e-03
>       0 KSP Residual norm 1.119259726469e-03
>       1 KSP Residual norm 6.758059074616e-05
>       0 KSP Residual norm 1.390217147343e-02
>       1 KSP Residual norm 1.994861880977e-03
>       3 KSP Residual norm 5.385911324388e-07
>     KSP Object:
>       type: fgmres
>         GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
> Orthogonalization with no iterative refinement
>         GMRES: happy breakdown tolerance 1e-30
>       maximum iterations=10000, initial guess is zero
>       tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
>       right preconditioning
>     PC Object:
>       type: mg
>       Coarse gride solver -- level 0 -------------------------------
>         KSP Object:(mg_coarse_)
>           type: preonly
>           maximum iterations=1, initial guess is zero
>           left preconditioning
>         PC Object:(mg_coarse_)
>           type: lu
>             LU: out-of-place factorization
>               matrix ordering: nd
>             LU: tolerance for zero pivot 1e-12
>             LU: factor fill ratio needed 1.54545
>                  Factored matrix follows
>                 Matrix Object:
>                   type=seqaij, rows=9, cols=9
>                   total: nonzeros=51, allocated nonzeros=51
>                     not using I-node routines
>           linear system matrix = precond matrix:
>           Matrix Object:
>             total: nonzeros=33, allocated nonzeros=33
> > On Mon, 11 Dec 2006, Nicolas Bathfield wrote:
> >>  Hi,
> >> I would like to compare PETSc DMMG convergence to some theoretical
> >> convergence rate given by local Fourier analysis for a simple diffusion
> >> problem.
> >> To do so, I need to extract the residuals after each multigrid
> >> iteration.
> >> Unfortunately, I only managed to obtain the residuals at the last
> >> iteration.
> >> Is it possible to get the residual printed out after each multigrid
> >> iteration without modifying the source code?
> >   Nicolas,
> >   -dmmg_ksp_monitor prints the residual after each V/W cycle.
> > -pc_mg_monitor
> > prints the residual norm before and after each smoothing step.
> >   BTW: always run with -ksp_view to see exactly what solver options
> > are being used. The defaults are non-standard (e.g. we default to having a
> > Krylov solver turned on for each smoother and the V/W cycle).
> >> Furthermore, I'd like to test the AMG from the PC type from HYPRE
> >> (boomeramg). I have already ran --download-hypre while compiling petsc.
> >> Is
> >> there any example available somewhere?
> >   -pc_type hypre -pc_hypre_type boomeramg
> > Run with -help to see the boomeramg options; again use -ksp_view we
> > default
> > to accelerating boomeramg with GMRES which is non-standard. Use -ksp_type
> > richardson
> > to get the usual V/W cycle.
> >   Good luck,
> >    Barry
> > Why the non-standard defaults? We want to provide a default MG that is as
> > robust
> > (more likely to converge) as possible. Hence we turn on ILU(0) smoothing
> > with GMRES
> > acceleration of the smoother and Krylov method. You can turn off these
> > options one
> > at a time to see the effect on the convergence rate. For model problems
> > the accelerators
> > only improve convergence a little. For more complex problems, for example
> > src/snes/examples/tutorials/ex19.c
> > convergence gets much worse without the accelerators.
> >> Best regards,
> >> Nicolas.
> >>  Nicolas BATHFIELD
> >>  Chalmers University of Technology
> >>  Shipping and Marine Technology
> >>  phone: +46 (0)31 772 1476
> >>  fax:   +46 (0)31 772 3699
