Problem with mpi
Ben Tay zonexo at gmail.com
Wed Dec 13 02:34:19 CST 2006
I have some problems with using mpi. My code works with one server but when
I test it on another system, I get the wrong answers. In that system, the
mpi is located at /usr/local/topspin/mpi/mpich/. I tried to specify it with
--with-mpi-dir but it wasn't able to find during config. I then add
--with-mpirun=/usr/local/topspin/mpi/mpich/bin/mpirun_ssh and it
compiled but wrong answers when run. May I know what file does it look for
if --with-mpi-lib is used? My lib64 directory has
libfmpich.a     libfmpich_p.a   libmpich.a        libmpichf90nc_i.a
libmpichf90nc_p.so  libmpichfsup.a     libmpichfsup_p.a   libmpich_i.a
libmpich_p.so  libpmpich++.so
libfmpich_i.a   libfmpich_p.so  libmpichf90_i.a   libmpichf90nc_i.so
libmpichf90_p.a     libmpichfsup_i.a   libmpichfsup_p.so  libmpich_i.so
libmpich.so
libfmpich_i.so  libfmpich.so    libmpichf90_i.so  libmpichf90nc_p.a
libmpichf90_p.so    libmpichfsup_i.so  libmpichfsup.so    libmpich_p.a
libpmpich++.a
I then tried to use --download-mpich=yes but the error msg is
         UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
details):
Error running configure on MPICH: Could not execute 'cd
/nfs/lsftmp/g0306332/petsc-2.3.2-p7/externalpackages/mpich2-1.0.4p1;./configure
--prefix=/nfs/lsftmp/g0306332/petsc-2.3.2-p7/externalpackages/mpich2-1.0.4p1/linux64-mpi-shared
CC="icc  -fPIC -g " --disable-cxx F90="ifort  -fPIC -g  " F77="ifort  -fPIC
-g  " --enable-sharedlibs=libtool --without-mpe --with-pm=gforker':
Configuring MPICH2 version 1.0.4p1 with
'--prefix=/nfs/lsftmp/g0306332/petsc-2.3.2-p7/externalpackages/mpich2-
1.0.4p1/linux64-mpi-shared' 'CC=icc  -fPIC -g ' '--disable-cxx' 'F90=ifort
-fPIC -g  ' 'F77=ifort  -fPIC -g  ' '--enable-sharedlibs=libtool'
'--without-mpe' '--with-pm=gforker'
Executing mpich2prereq in /nfs/lsftmp/g0306332/petsc-2.3.2-p7
/externalpackages/mpich2-1.0.4p1/src/mpid/ch3 with
/externalpackages/mpich2-1.0.4p1/src/mpid/ch3/channels/sock
sourcing /nfs/lsftmp/g0306332/petsc-2.3.2-p7/externalpackages/mpich2-1.0.4p1
/src/pm/gforker/mpich2prereq
checking for gcc... icc  -fPIC -g
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether icc  -fPIC -g  accepts -g... yes
checking for icc  -fPIC -g  option to accept ANSI C... none needed
checking for type of weak symbol support... pragma weak
checking whether __attribute__ ((weak)) allowed... yes
checking for multiple weak symbol support... yes
checking whether we are using the GNU Fortran 77 compiler... no
checking whether ifort  -fPIC -g   accepts -g... yes
checking how to get verbose linking output from ifort  -fPIC -g  ... -v
checking for Fortran libraries of ifort  -fPIC -g  ...
-L/usr/local/intel/fc9.0/lib -L/usr/lib/gcc/x86_64-redhat-linux/3.4.6/
-L/usr/lib/gcc/x86_64-redhat-linux/3.4.6/../../../../lib64 -lsvml -lifport
-lifcore -limf -lm -lirc -lgcc_s -lirc_s
checking whether C can link with  -L/usr/local/intel/fc9.0/lib
-lifcore -limf -lm -lirc -lgcc_s -lirc_s... yes
checking for linker for Fortran main programs... Use Fortran to link
programs
checking for Fortran 77 name mangling... lower underscore
checking that f works as the extension for Fortran 90 program... yes
checking whether we are using the GNU Fortran 90 compiler... no
checking for extension for Fortran 90 programs... f90
checking whether the Fortran 90 compiler (ifort  -fPIC -g    ) works... yes
checking whether the Fortran 90 compiler (ifort  -fPIC -g    ) is a
cross-compiler... no
checking whether Fortran 90 works with Fortran 77... yes
checking whether Fortran accepts ! for comments... yes
checking for include directory flag for Fortran... -I
checking for Fortran 77 flag for library directories... -L
checking for which Fortran libraries are needed to link C with Fortran...
none
checking whether Fortran compiler processes .F files with C preprocessor...
yes
checking whether we are using the GNU Fortran 90 compiler... (cached) no
checking whether ifort  -fPIC -g   accepts -g... (cached) yes
checking for Fortran 90 module extension... mod
checking for Fortran 90 module include flag... -I
checking whether Fortran 90 accepts f90 suffix... yes
checking whether Fortran 90 compiler processes .F90 files with C
preprocessor... yes
checking for f90 compiler vendor... intel
checking for perl... /usr/bin/perl
checking for ar... ar
checking for ranlib... ranlib
checking for etags... etags
checking for etags argument to specify language... --language=c
checking whether global variables handled properly... yes
checking for a BSD-compatible install... /usr/bin/install -c
checking whether install works... yes
checking whether install breaks libraries... no
checking whether mkdir -p works... yes
checking for make... make
checking whether clock skew breaks make... no
checking whether make supports include... yes
checking whether make allows comments in actions... yes
checking for virtual path format... VPATH
checking whether make sets CFLAGS... no
checking for bash... /bin/sh
checking whether /bin/sh supports arrays... yes
configure: error: Creating shared libraries using libtool not yet supported
May I know what's wrong?
Thank you.
Regards
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20061213/78d3612d/attachment.htm>
