Configuration crash - can't start new thread
Ben Tay zonexo at gmail.com
Mon Dec 11 04:23:22 CST 2006
Hi Satish,
Can you explain a bit how to change the RDict.py? I don't understand what
you mean.
Thank you.
On 12/7/06, Satish Balay <balay at mcs.anl.gov> wrote:
> On Thu, 7 Dec 2006, Satish Balay wrote:
> > I'll sugest using a different machine for install.
> Can you try the following change to python/BuildSystem/RDict.py - and
> then run configure with the option '--useThreads=0' - and see if it
> works?
> Satish
> diff -r e6686438867b90e62e969d5f96189924d4bd27f2 RDict.py
> --- a/RDict.py  Thu Dec 07 09:09:11 2006 -0600
> +++ b/RDict.py  Thu Dec 07 09:09:36 2006 -0600
> @@ -624,6 +624,7 @@ Arg class, which wraps the usual value.'
>   def save(self, force = 0):
>     '''Save the dictionary after 5 seconds, ignoring all subsequent calls
> until the save
>        - Giving force = True will cause an immediate save'''
> +    return 0
>     if force:
>       self.saveTimer = None
>       # This should be a critical section
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20061211/114c445f/attachment.htm>
