Configuration crash - can't start new thread
Thu Dec 7 09:12:52 CST 2006
On Thu, 7 Dec 2006, Satish Balay wrote:
> I'll sugest using a different machine for install.
Can you try the following change to python/BuildSystem/RDict.py - and
then run configure with the option '--useThreads=0' - and see if it
works?
Satish
diff -r e6686438867b90e62e969d5f96189924d4bd27f2 RDict.py
--- a/RDict.py  Thu Dec 07 09:09:11 2006 -0600
+++ b/RDict.py  Thu Dec 07 09:09:36 2006 -0600
@@ -624,6 +624,7 @@ Arg class, which wraps the usual value.'
   def save(self, force = 0):
     '''Save the dictionary after 5 seconds, ignoring all subsequent calls until the save
        - Giving force = True will cause an immediate save'''
+    return 0
     if force:
       self.saveTimer = None
       # This should be a critical section
