DA Jacobian
Sat Dec 9 11:49:29 CST 2006
ADIC is not able to be freely distributed. You must contact the developers.
  Matt
On 12/9/06, Jianing Shi <js2615 at columbia.edu> wrote:
> I just added PETSC_HAVE_ADIC, and seems that the compiler does not
> complain any more.
>   #if defined(PETSC_HAVE_ADIC)
>   if (adicmf_jacobian)
>     ierr =
> DASetLocalAdicMFFunction(user.da,admf_FormFunctionLocal);CHKERRQ(ierr);
>     ierr = MatRegisterDAAD();CHKERRQ(ierr);
>     ierr = MatCreateDAAD(user.da,&A);CHKERRQ(ierr);
>     ierr = MatDAADSetSNES(A,snes);CHKERRQ(ierr);
>     ierr = MatDAADSetCtx(A,&user);CHKERRQ(ierr);
>   #endif
> Though what is the trick if I really want to use ADIC?
> Jianing
> Quoting Matthew Knepley <knepley at gmail.com>:
> > Are you really using ADIC?
> >   Matt
> > > I have a question about creating the jacobian here.
> > > Here is the code I use to create it.
> > >   ierr = DAGetMatrix(user.da,MATAIJ,&J);CHKERRQ(ierr);
> > >   A = J;
> > >   ierr =
> > > I included the head files
> > > petscsnes.h    petscda.h
> > > When I compile it, I got the following linking error:
> > > ld: Undefined symbols:
> > > _MatCreateDAAD
> > > _MatDAADSetCtx
> > > _MatDAADSetSNES
> > > _MatRegisterDAAD
> > > make: [paraImplicitV1] Error 1 (ignored)
> > > Not sure what went wrong.
> > > Jianing
> > "Failure has a thousand explanations. Success doesn't need one"
> > -- Sir
> > Alec Guiness
"Failure has a thousand explanations. Success doesn't need one" -- Sir
Alec Guiness
