DA Jacobian
Jianing Shi js2615 at columbia.edu
Sat Dec 9 11:45:03 CST 2006
I just added PETSC_HAVE_ADIC, and seems that the compiler does not
complain any more.
  #if defined(PETSC_HAVE_ADIC)
  if (adicmf_jacobian)
    ierr =
DASetLocalAdicMFFunction(user.da,admf_FormFunctionLocal);CHKERRQ(ierr);
    ierr = MatRegisterDAAD();CHKERRQ(ierr);
    ierr = MatCreateDAAD(user.da,&A);CHKERRQ(ierr);
    ierr = MatDAADSetSNES(A,snes);CHKERRQ(ierr);
    ierr = MatDAADSetCtx(A,&user);CHKERRQ(ierr);
  #endif
Though what is the trick if I really want to use ADIC?
Jianing
Quoting Matthew Knepley <knepley at gmail.com>:
> Are you really using ADIC?
>   Matt
> On 12/9/06, Jianing Shi <js2615 at columbia.edu> wrote:
> > I have a question about creating the jacobian here.
> > Here is the code I use to create it.
> >   ierr = DAGetMatrix(user.da,MATAIJ,&J);CHKERRQ(ierr);
> >   A = J;
> >   ierr =
> > I included the head files
> > petscsnes.h    petscda.h
> > When I compile it, I got the following linking error:
> > ld: Undefined symbols:
> > _MatCreateDAAD
> > _MatDAADSetCtx
> > _MatDAADSetSNES
> > _MatRegisterDAAD
> > make: [paraImplicitV1] Error 1 (ignored)
> > Not sure what went wrong.
> > Jianing
> "Failure has a thousand explanations. Success doesn't need one"
> -- Sir
> Alec Guiness
