[petsc-dev] DMPlex overlap redistribution
Fri Mar 8 11:50:56 CST 2024
On Thu, Mar 7, 2024 at 12:08 AM Adrian Croucher <a.croucher at auckland.ac.nz>
wrote:
> hi Matt,
> With a bit more experimenting, I find I get the same sort of error in
> DMPlexStratify() if I run a very simple program that just reads in a
> DMPlex from file and then stratifies it (no dual porosity, no
> distribution etc.), i.e.:
>    call DMPlexCreateFromFile(PETSC_COMM_WORLD, 'gminc_1d.exo', 'mesh', &
>         PETSC_TRUE, dm, ierr)
>    call DMPlexStratify(dm, ierr)
> The error again looks like this:
> [0]PETSC ERROR: Petsc has generated inconsistent data
> [0]PETSC ERROR: New depth 0 range [10,54) overlaps with depth 0 range
> [10,54)
> Would you expect that to work?
Here is what is happening in this case. The DMPlexCreateFromFile() call
already stratifies the mesh.
Then the call DMPlexStratify() attempts to do this again. There is a check
in DMPlexCreateDepthStratum()
that checks for overlap. If we want to call this again, we first need to
wipe out the depth label. I wasn't sure I wanted DMPlexStratify() to do
this automatically, but maybe it should.
     Matt
> - Adrian
> Dr Adrian Croucher
> Senior Research Fellow
> Department of Engineering Science
> Waipapa Taumata Rau / University of Auckland, New Zealand
> email: a.croucher at auckland.ac.nz
> tel: +64 (0)9 923 4611
experiments lead.
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!egE85226em0pMIxZzhtCDoypqqpVkgjeDShU6xwNDaUaSg_Yalo45qmkBBW2k1X4NfXTdLKw0pfSGPXryDoa$  <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!egE85226em0pMIxZzhtCDoypqqpVkgjeDShU6xwNDaUaSg_Yalo45qmkBBW2k1X4NfXTdLKw0pfSGAOd7xGB$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20240308/ae58e4b9/attachment.html>
