[petsc-dev] Issue with -log_view
Tue May 9 07:13:35 CDT 2023
On Tue, May 9, 2023 at 7:17 AM Jose E. Roman <jroman at dsic.upv.es> wrote:
> Hi.
> We are seeing a strange thing in the -log_view output with one of the
> SLEPc solvers. It is probably an issue with SLEPc, but we don't know how to
> debug it.
> It can be reproduced for instance with
>  $ ./ex45 -m 15 -n 20 -p 21 -svd_nsv 4 -svd_ncv 9 -log_view
> The log_view events are listed at the end of this email. The first one
> (PetscBarrier) is wrong, because PetscBarrier is never called, if I place a
> breakpoint in PetscBarrier() it will never be hit. Also, in that event it
> reports some nonzero Mflop/s, which suggests that it corresponds to another
> event (not PetscBarrier). Furthermore, the count of the PetscBarrier event
> always matches the count of MatMultTranspose, so there must be a connection.
> Does anyone have suggestions how to address this?
Hi Jose,
Here is my guess. PETSc sets all of the event ids (using Register) when the
dynamic libraries get loaded. If they are not loaded,
then the library initialization function is called when some function from
that library is used. My guess is that we put this init check
in MatCreate(), but that is not called when you create your shell matrix
and thus the events are not initialized correctly for you until
later. Can you check?
     Matt
> Note: this is with 1 MPI process.
> Note: the solver creates a shell matrix with MATOP_MULT_TRANSPOSE.
> Thanks.
> Jose
> PetscBarrier          16 1.0 7.5579e-04 1.0 4.38e+03 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0     6
> MatMult               82 1.0 6.1590e-01 1.0 9.25e+05 1.0 0.0e+00 0.0e+00
> 0.0e+00 81 97  0  0  0  81 97  0  0  0     2
> MatMultTranspose      16 1.0 7.4625e-04 1.0 4.38e+03 1.0 0.0e+00 0.0e+00
> MatAssemblyBegin       4 1.0 5.2452e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> MatAssemblyEnd         4 1.0 2.8920e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> MatTranspose           2 1.0 1.6265e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> SVDSetUp               1 1.0 1.8686e-02 1.0 2.72e+02 1.0 0.0e+00 0.0e+00
> 0.0e+00  2  0  0  0  0   2  0  0  0  0     0
> SVDSolve               1 1.0 5.5965e-01 1.0 7.95e+05 1.0 0.0e+00 0.0e+00
> 0.0e+00 74 83  0  0  0  74 83  0  0  0     1
> EPSSetUp               1 1.0 9.5146e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
> EPSSolve               1 1.0 5.4082e-01 1.0 7.94e+05 1.0 0.0e+00 0.0e+00
> 0.0e+00 71 83  0  0  0  71 83  0  0  0     1
> STSetUp                1 1.0 4.8406e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> STComputeOperatr       1 1.0 1.2653e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> STApply               24 1.0 6.1569e-01 1.0 8.84e+05 1.0 0.0e+00 0.0e+00
> 0.0e+00 81 92  0  0  0  81 92  0  0  0     1
> STMatSolve            24 1.0 6.1556e-01 1.0 8.80e+05 1.0 0.0e+00 0.0e+00
> KSPSetUp               1 1.0 2.8465e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> KSPSolve              24 1.0 6.1551e-01 1.0 8.80e+05 1.0 0.0e+00 0.0e+00
> KSPGMRESOrthog       480 1.0 4.3219e-01 1.0 3.98e+05 1.0 0.0e+00 0.0e+00
> 0.0e+00 57 42  0  0  0  57 42  0  0  0     1
> PCSetUp                1 1.0 3.8147e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> PCApply              504 1.0 2.1615e-02 1.0 1.01e+04 1.0 0.0e+00 0.0e+00
> 0.0e+00  3  1  0  0  0   3  1  0  0  0     0
> BVCopy                27 1.0 3.0560e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> BVMultVec             38 1.0 3.7060e-03 1.0 8.88e+03 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  1  0  0  0   0  1  0  0  0     2
> BVMultInPlace          3 1.0 1.0681e-04 1.0 4.32e+03 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0    40
> BVDotVec              38 1.0 4.5121e-03 1.0 4.38e+04 1.0 0.0e+00 0.0e+00
> 0.0e+00  1  5  0  0  0   1  5  0  0  0    10
> BVOrthogonalizeV      20 1.0 1.3182e-02 1.0 5.33e+04 1.0 0.0e+00 0.0e+00
> 0.0e+00  2  6  0  0  0   2  6  0  0  0     4
> BVScale               24 1.0 4.8089e-04 1.0 4.80e+02 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0     1
> BVNormVec              4 1.0 5.4097e-04 1.0 3.67e+03 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0     7
> BVNormalize            1 1.0 1.3154e-03 1.0 3.75e+03 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0     3
> BVSetRandom            1 1.0 9.1791e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> BVMatMultVec          19 1.0 4.6828e-01 1.0 6.99e+05 1.0 0.0e+00 0.0e+00
> 0.0e+00 62 73  0  0  0  62 73  0  0  0     1
> DSSolve                3 1.0 8.8906e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> DSVectors              7 1.0 2.8920e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> DSOther               12 1.0 3.8576e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> VecDot                 4 1.0 8.7500e-05 1.0 1.56e+02 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0     2
> VecMDot              488 1.0 6.0463e-04 1.0 1.98e+05 1.0 0.0e+00 0.0e+00
> 0.0e+00  0 21  0  0  0   0 21  0  0  0   327
> VecNorm              520 1.0 1.0412e-02 1.0 2.02e+04 1.0 0.0e+00 0.0e+00
> 0.0e+00  1  2  0  0  0   1  2  0  0  0     2
> VecScale             514 1.0 1.0245e-02 1.0 1.03e+04 1.0 0.0e+00 0.0e+00
> 0.0e+00  1  1  0  0  0   1  1  0  0  0     1
> VecCopy               62 1.0 1.8365e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> VecSet                64 1.0 4.2200e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> VecAXPY               32 1.0 4.8995e-04 1.0 1.44e+03 1.0 0.0e+00 0.0e+00
> VecMAXPY             504 1.0 6.9070e-04 1.0 2.21e+05 1.0 0.0e+00 0.0e+00
> 0.0e+00  0 23  0  0  0   0 23  0  0  0   320
> VecPointwiseMult     504 1.0 3.3593e-04 1.0 1.01e+04 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  1  0  0  0   0  1  0  0  0    30
> VecSetRandom           1 1.0 5.0068e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> VecNormalize         512 1.0 4.1106e-02 1.0 3.01e+04 1.0 0.0e+00 0.0e+00
> 0.0e+00  5  3  0  0  0   5  3  0  0  0     1
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20230509/1319a5db/attachment-0001.html>
