[petsc-dev] Issue with -log_view
Jose E. Roman jroman at dsic.upv.es
Tue May 9 06:17:26 CDT 2023
Hi.
We are seeing a strange thing in the -log_view output with one of the SLEPc solvers. It is probably an issue with SLEPc, but we don't know how to debug it.
It can be reproduced for instance with
 $ ./ex45 -m 15 -n 20 -p 21 -svd_nsv 4 -svd_ncv 9 -log_view
The log_view events are listed at the end of this email. The first one (PetscBarrier) is wrong, because PetscBarrier is never called, if I place a breakpoint in PetscBarrier() it will never be hit. Also, in that event it reports some nonzero Mflop/s, which suggests that it corresponds to another event (not PetscBarrier). Furthermore, the count of the PetscBarrier event always matches the count of MatMultTranspose, so there must be a connection.
Does anyone have suggestions how to address this?
Note: this is with 1 MPI process.
Note: the solver creates a shell matrix with MATOP_MULT_TRANSPOSE.
Thanks.
Jose
PetscBarrier          16 1.0 7.5579e-04 1.0 4.38e+03 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     6
MatMult               82 1.0 6.1590e-01 1.0 9.25e+05 1.0 0.0e+00 0.0e+00 0.0e+00 81 97  0  0  0  81 97  0  0  0     2
MatMultTranspose      16 1.0 7.4625e-04 1.0 4.38e+03 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     6
MatAssemblyBegin       4 1.0 5.2452e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAssemblyEnd         4 1.0 2.8920e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatTranspose           2 1.0 1.6265e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SVDSetUp               1 1.0 1.8686e-02 1.0 2.72e+02 1.0 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0   2  0  0  0  0     0
SVDSolve               1 1.0 5.5965e-01 1.0 7.95e+05 1.0 0.0e+00 0.0e+00 0.0e+00 74 83  0  0  0  74 83  0  0  0     1
EPSSetUp               1 1.0 9.5146e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
EPSSolve               1 1.0 5.4082e-01 1.0 7.94e+05 1.0 0.0e+00 0.0e+00 0.0e+00 71 83  0  0  0  71 83  0  0  0     1
STSetUp                1 1.0 4.8406e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
STComputeOperatr       1 1.0 1.2653e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
STApply               24 1.0 6.1569e-01 1.0 8.84e+05 1.0 0.0e+00 0.0e+00 0.0e+00 81 92  0  0  0  81 92  0  0  0     1
STMatSolve            24 1.0 6.1556e-01 1.0 8.80e+05 1.0 0.0e+00 0.0e+00 0.0e+00 81 92  0  0  0  81 92  0  0  0     1
KSPSetUp               1 1.0 2.8465e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPSolve              24 1.0 6.1551e-01 1.0 8.80e+05 1.0 0.0e+00 0.0e+00 0.0e+00 81 92  0  0  0  81 92  0  0  0     1
KSPGMRESOrthog       480 1.0 4.3219e-01 1.0 3.98e+05 1.0 0.0e+00 0.0e+00 0.0e+00 57 42  0  0  0  57 42  0  0  0     1
PCSetUp                1 1.0 3.8147e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
PCApply              504 1.0 2.1615e-02 1.0 1.01e+04 1.0 0.0e+00 0.0e+00 0.0e+00  3  1  0  0  0   3  1  0  0  0     0
BVCopy                27 1.0 3.0560e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
BVMultVec             38 1.0 3.7060e-03 1.0 8.88e+03 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0     2
BVMultInPlace          3 1.0 1.0681e-04 1.0 4.32e+03 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0    40
BVDotVec              38 1.0 4.5121e-03 1.0 4.38e+04 1.0 0.0e+00 0.0e+00 0.0e+00  1  5  0  0  0   1  5  0  0  0    10
BVOrthogonalizeV      20 1.0 1.3182e-02 1.0 5.33e+04 1.0 0.0e+00 0.0e+00 0.0e+00  2  6  0  0  0   2  6  0  0  0     4
BVScale               24 1.0 4.8089e-04 1.0 4.80e+02 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     1
BVNormVec              4 1.0 5.4097e-04 1.0 3.67e+03 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     7
BVNormalize            1 1.0 1.3154e-03 1.0 3.75e+03 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     3
BVSetRandom            1 1.0 9.1791e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
BVMatMultVec          19 1.0 4.6828e-01 1.0 6.99e+05 1.0 0.0e+00 0.0e+00 0.0e+00 62 73  0  0  0  62 73  0  0  0     1
DSSolve                3 1.0 8.8906e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
DSVectors              7 1.0 2.8920e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
DSOther               12 1.0 3.8576e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecDot                 4 1.0 8.7500e-05 1.0 1.56e+02 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     2
VecMDot              488 1.0 6.0463e-04 1.0 1.98e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0 21  0  0  0   0 21  0  0  0   327
VecNorm              520 1.0 1.0412e-02 1.0 2.02e+04 1.0 0.0e+00 0.0e+00 0.0e+00  1  2  0  0  0   1  2  0  0  0     2
VecScale             514 1.0 1.0245e-02 1.0 1.03e+04 1.0 0.0e+00 0.0e+00 0.0e+00  1  1  0  0  0   1  1  0  0  0     1
VecCopy               62 1.0 1.8365e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet                64 1.0 4.2200e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY               32 1.0 4.8995e-04 1.0 1.44e+03 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     3
VecMAXPY             504 1.0 6.9070e-04 1.0 2.21e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0 23  0  0  0   0 23  0  0  0   320
VecPointwiseMult     504 1.0 3.3593e-04 1.0 1.01e+04 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0    30
VecSetRandom           1 1.0 5.0068e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecNormalize         512 1.0 4.1106e-02 1.0 3.01e+04 1.0 0.0e+00 0.0e+00 0.0e+00  5  3  0  0  0   5  3  0  0  0     1
