[petsc-dev] petsc4py doc problem
Stefano Zampini stefano.zampini at gmail.com
Wed Jun 28 01:50:53 CDT 2023
I have added a check to 79 characters lines in petsc4py docstrings.  Just
split the lines that are longer than that.
On Wed, Jun 28, 2023, 04:07 Matthew Knepley <knepley at gmail.com> wrote:
> I do not understand those docs at all:
> Using PETSC inventory from
> file:///scratch/svcpetsc/glci-builds-stage2/VW-hbPim/0/petsc/petsc/public/html/objects.inv
> <Inventory (url): PETSc vv3.19.2-597-g38258f1efa0, 7486 objects>
> Warning, treated as error:
> Line 9 for Mat.setLRCMats(self, A: Mat, U: Mat, c: Vec | None = None, V:
> Mat | None = None) too long.
>   https://gitlab.com/petsc/petsc/-/jobs/4554950030
> Can someone fix this? https://gitlab.com/petsc/petsc/-/merge_requests/6640
>   Thanks,
>      Matt
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20230628/dd757519/attachment-0001.html>
