[petsc-dev] petsc4py doc problem
Wed Jun 28 00:03:49 CDT 2023
https://gitlab.com/petsc/petsc/-/merge_requests/6578/commits
commit 0898713fbecf5e265dbd1d072d2bffc3dcf92948
Author: Stefano Zampini <stefano.zampini at gmail.com>
Date:   Sat Jun 17 20:40:28 2023 +0200
    petsc4py docs: enforce 79 characters lines
so perhaps:
diff --git a/src/binding/petsc4py/src/petsc4py/PETSc/Mat.pyx b/src/binding/petsc4py/src/petsc4py/PETSc/Mat.pyx
index 067d98e3b0b..c04f501c73b 100644
--- a/src/binding/petsc4py/src/petsc4py/PETSc/Mat.pyx
+++ b/src/binding/petsc4py/src/petsc4py/PETSc/Mat.pyx
@@ -4745,7 +4745,8 @@ cdef class Mat(Object):
         U : Mat
             The first dense rectangular matrix.
         c : Vec
-            The sequential vector containing the diagonal of ``C``, or NULL for all ones.
+            The sequential vector containing the diagonal of ``C``,
+            or NULL for all ones.
         V : Mat
             The second dense rectangular matrix, or NULL for a copy of ``U``.
Satish
On Tue, 27 Jun 2023, Matthew Knepley wrote:
> I do not understand those docs at all:
> Using PETSC inventory from
> file:///scratch/svcpetsc/glci-builds-stage2/VW-hbPim/0/petsc/petsc/public/html/objects.inv
> <Inventory (url): PETSc vv3.19.2-597-g38258f1efa0, 7486 objects>
> Warning, treated as error:
> Line 9 for Mat.setLRCMats(self, A: Mat, U: Mat, c: Vec | None = None, V:
> Mat | None = None) too long.
>   https://gitlab.com/petsc/petsc/-/jobs/4554950030
> Can someone fix this? https://gitlab.com/petsc/petsc/-/merge_requests/6640
>   Thanks,
>      Matt
