[petsc-dev] GCov CI problem
Barry Smith bsmith at petsc.dev
Wed Jun 14 13:42:53 CDT 2023
 Strange this never bit before, you could put in requires: for this example no gcov
> On Jun 14, 2023, at 2:37 PM, Satish Balay via petsc-dev <petsc-dev at mcs.anl.gov> wrote:
> not ok vec_pf_impls_string_tests-ex1_1 # Error code: 65
> #       [0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> #       [0]PETSC ERROR: Unable to open file
> #       [0]PETSC ERROR: Unable to open dynamic library:
> #         /tmp/svcpetsc/libpetscdlib.so
> which part of code is creating and loading a library from this location?
> src/vec/pf/impls/string/cstring.c:  PetscCall(PetscSNPrintf(task, PETSC_STATIC_ARRAY_LENGTH(task), "cd %s ; if [ ! -d ${USERNAME} ]; then mkdir ${USERNAME}; fi ; cd ${USERNAME} ; rm -f makefile petscdlib.* ; cp -f ${PETSC_DIR}/src/vec/pf/impls/string/makefile ./makefile ; ${PETSC_MAKE} NIN=%" PetscInt_FMT " NOUT=%" PetscInt_FMT " -f makefile libpetscdlib STRINGFUNCTION=\"%s\"  %s ;  sync\n", tmp, pf->dimin, pf->dimout, string, keeptmpfiles ? "; rm -f makefile petscdlib.c" : ""));
> a library should be doing such a thing - in a common location [however useful such a feature is :(]
> Satish
> On Wed, 14 Jun 2023, Matthew Knepley wrote:
>> https://gitlab.com/petsc/petsc/-/jobs/4474550390
>> It looks like some gcov stuff is failing in the CI, unrelated to this MR.
>>  Thanks,
>>     Matt
