[petsc-dev] GCov CI problem
Wed Jun 14 13:37:27 CDT 2023
not ok vec_pf_impls_string_tests-ex1_1 # Error code: 65
#       [0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
#       [0]PETSC ERROR: Unable to open file
#       [0]PETSC ERROR: Unable to open dynamic library:
#         /tmp/svcpetsc/libpetscdlib.so
which part of code is creating and loading a library from this location?
src/vec/pf/impls/string/cstring.c:  PetscCall(PetscSNPrintf(task, PETSC_STATIC_ARRAY_LENGTH(task), "cd %s ; if [ ! -d ${USERNAME} ]; then mkdir ${USERNAME}; fi ; cd ${USERNAME} ; rm -f makefile petscdlib.* ; cp -f ${PETSC_DIR}/src/vec/pf/impls/string/makefile ./makefile ; ${PETSC_MAKE} NIN=%" PetscInt_FMT " NOUT=%" PetscInt_FMT " -f makefile libpetscdlib STRINGFUNCTION=\"%s\"  %s ;  sync\n", tmp, pf->dimin, pf->dimout, string, keeptmpfiles ? "; rm -f makefile petscdlib.c" : ""));
a library should be doing such a thing - in a common location [however useful such a feature is :(]
Satish
On Wed, 14 Jun 2023, Matthew Knepley wrote:
> https://gitlab.com/petsc/petsc/-/jobs/4474550390
> It looks like some gcov stuff is failing in the CI, unrelated to this MR.
>   Thanks,
>      Matt
