[petsc-dev] GCC8 Fortran length changes from int to size_t
Wed May 2 11:50:31 CDT 2018
On Wed, May 2, 2018 at 12:15 PM, Jed Brown <jed at jedbrown.org> wrote:
> Lisandro Dalcin <dalcinl at gmail.com> writes:
> > On Wed, 2 May 2018 at 17:29, Satish Balay <balay at mcs.anl.gov> wrote:
> >> So we need a 64bit arm with gcc8 - for this testcase failure?
> > Or a big-endian machine/OS ?
> Shouldn't be necessary, but why are we so concerned about making a test
> case fail instead of implementing correct behavior?
How would you know your fix was correct?
   Matt
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180502/4d1796a2/attachment.html>
