[petsc-dev] Fwd: PETSc blame digest (next) 2017-05-26
Stefano Zampini stefano.zampini at gmail.com
Fri May 26 09:10:47 CDT 2017
odm is not used in next, see
https://bitbucket.org/petsc/petsc/src/14da202a66307a428d971aa05155573b842639fd/src/dm/impls/plex/plexadapt.c?at=next&fileviewer=file-view-default#plexadapt.c-71 <https://bitbucket.org/petsc/petsc/src/14da202a66307a428d971aa05155573b842639fd/src/dm/impls/plex/plexadapt.c?at=next&fileviewer=file-view-default#plexadapt.c-71>
> On May 26, 2017, at 4:04 PM, Matthew Knepley <knepley at gmail.com> wrote:
> Does anyone understand this? It seems clear that odm is used.
>    Matt
> ---------- Forwarded message ----------
> From: PETSc checkBuilds <petsc-checkbuilds at mcs.anl.gov <mailto:petsc-checkbuilds at mcs.anl.gov>>
> Date: Fri, May 26, 2017 at 9:00 AM
> Subject: PETSc blame digest (next) 2017-05-26
> To: Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>>, PETSc checkBuilds <petsc-checkbuilds at mcs.anl.gov <mailto:petsc-checkbuilds at mcs.anl.gov>>
> Dear PETSc developer,
> This email contains listings of contributions attributed to you by
> `git blame` that caused compiler errors or warnings in PETSc automated
> testing.  Follow the links to see the full log files. Please attempt to fix
> the issues promptly or let us know at petsc-dev at mcs.anl.gov <mailto:petsc-dev at mcs.anl.gov> if you are unable
> to resolve the issues.
> Thanks,
>   The PETSc development team
> warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/a2e1bd4 <https://bitbucket.org/petsc/petsc/commits/a2e1bd4>
> Plex: Fix adaptation for serial case
>   src/dm/impls/plex/plexadapt.c:26
>     [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/05/26/build_next_arch-linux-uni_crush.log <http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/05/26/build_next_arch-linux-uni_crush.log>]
>       /sandbox/petsc/petsc.clone-2/src/dm/impls/plex/plexadapt.c:26:22: warning: unused variable 'odm' [-Wunused-variable]
>     [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/05/26/build_next_arch-linux-pkgs-opt_crank.log <http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/05/26/build_next_arch-linux-pkgs-opt_crank.log>]
>       /sandbox/petsc/petsc.clone/src/dm/impls/plex/plexadapt.c:26:22: warning: unused variable 'odm' [-Wunused-variable]
>     [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/05/26/build_next_arch-linux-gcc-absoft_churn.log <http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/05/26/build_next_arch-linux-gcc-absoft_churn.log>]
>     [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/05/26/build_next_arch-cuda-single_es.log <http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/05/26/build_next_arch-cuda-single_es.log>]
>     [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/05/26/build_next_arch-osx-10.6-cxx-pkgs-opt_ipro.log <http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/05/26/build_next_arch-osx-10.6-cxx-pkgs-opt_ipro.log>]
>       /Users/petsc/petsc.clone-2/src/dm/impls/plex/plexadapt.c:26:22: warning: unused variable 'odm' [-Wunused-variable]
>     [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/05/26/build_next_arch-linux-pkgs-cxx-mlib_el6.log <http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/05/26/build_next_arch-linux-pkgs-cxx-mlib_el6.log>]
>       /sandbox/petsc/petsc.clone-3/src/dm/impls/plex/plexadapt.c:26:22: warning: unused variable 'odm' [-Wunused-variable]
>     [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/05/26/build_next_arch-linux-opt-cxx-quad_grind.log <http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/05/26/build_next_arch-linux-opt-cxx-quad_grind.log>]
>     [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/05/26/build_next_arch-linux-xsdk-dbg_cg.log <http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/05/26/build_next_arch-linux-xsdk-dbg_cg.log>]
>     [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/05/26/build_next_arch-linux-without-fc_cg.log <http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/05/26/build_next_arch-linux-without-fc_cg.log>]
>     [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/05/26/build_next_arch-linux-xsdk-latest_cg.log <http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/05/26/build_next_arch-linux-xsdk-latest_cg.log>]
>       /sandbox/petsc/petsc.clone-4/src/dm/impls/plex/plexadapt.c:26:22: warning: unused variable 'odm' [-Wunused-variable]
>     [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/05/26/build_next_arch-linux-IPL64_thrash.log <http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/05/26/build_next_arch-linux-IPL64_thrash.log>]
>     [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/05/26/build_next_arch-linux-cxx-cmplx-pkgs-64idx_churn.log <http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/05/26/build_next_arch-linux-cxx-cmplx-pkgs-64idx_churn.log>]
>     [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/05/26/build_next_arch-linux-dbg-quad_churn.log <http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/05/26/build_next_arch-linux-dbg-quad_churn.log>]
>     [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/05/26/build_next_arch-linux-pkgs-threadcomm_el6.log <http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/05/26/build_next_arch-linux-pkgs-threadcomm_el6.log>]
>     [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/05/26/build_next_arch-osx-10.6_ipro.log <http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/05/26/build_next_arch-osx-10.6_ipro.log>]
>       /Users/petsc/petsc.clone/src/dm/impls/plex/plexadapt.c:26:22: warning: unused variable 'odm' [-Wunused-variable]
>     [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/05/26/build_next_arch-freebsd-cxx-pkgs-opt_wii.log <http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/05/26/build_next_arch-freebsd-cxx-pkgs-opt_wii.log>]
>       /usr/home/balay/petsc.clone-2/src/dm/impls/plex/plexadapt.c:26:22: warning: unused variable 'odm' [-Wunused-variable]
>     [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/05/26/build_next_arch-freebsd-cxx-cmplx-pkgs-dbg_wii.log <http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/05/26/build_next_arch-freebsd-cxx-cmplx-pkgs-dbg_wii.log>]
>       /usr/home/balay/petsc.clone-3/src/dm/impls/plex/plexadapt.c:26:22: warning: unused variable 'odm' [-Wunused-variable]
>     [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/05/26/build_next_arch-osx-10.6-cxx-cmplx-pkgs-dbg_ipro.log <http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/05/26/build_next_arch-osx-10.6-cxx-cmplx-pkgs-dbg_ipro.log>]
>       /Users/petsc/petsc.clone-3/src/dm/impls/plex/plexadapt.c:26:22: warning: unused variable 'odm' [-Wunused-variable]
>     [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/05/26/build_next_arch-freebsd-pkgs-opt_wii.log <http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/05/26/build_next_arch-freebsd-pkgs-opt_wii.log>]
>       /usr/home/balay/petsc.clone/src/dm/impls/plex/plexadapt.c:26:22: warning: unused variable 'odm' [-Wunused-variable]
>     [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/05/26/build_next_arch-c-exodus-dbg-builder_es.log <http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/05/26/build_next_arch-c-exodus-dbg-builder_es.log>]
>     [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/05/26/build_next_arch-linux-pkgs-dbg-ftn-interfaces_crank.log <http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/05/26/build_next_arch-linux-pkgs-dbg-ftn-interfaces_crank.log>]
>     [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/05/26/build_next_arch-linux-pkgs-valgrind_el6.log <http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/05/26/build_next_arch-linux-pkgs-valgrind_el6.log>]
>     [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/05/26/build_next_arch-viennacl_es.log <http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/05/26/build_next_arch-viennacl_es.log>]
>     [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/05/26/build_next_arch-cuda-double_es.log <http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/05/26/build_next_arch-cuda-double_es.log>]
>     [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/05/26/build_next_arch-osx-xsdk-opt_ipro.log <http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/05/26/build_next_arch-osx-xsdk-opt_ipro.log>]
>       /Users/petsc/petsc.clone-4/src/dm/impls/plex/plexadapt.c:26:22: warning: unused variable 'odm' [-Wunused-variable]
>     [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/05/26/build_next_arch-linux-pkgs-64idx_thrash.log <http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/05/26/build_next_arch-linux-pkgs-64idx_thrash.log>]
>     [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/05/26/build_next_arch-linux-gcc-ifc-cmplx_crank.log <http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/05/26/build_next_arch-linux-gcc-ifc-cmplx_crank.log>]
> To opt-out from receiving these messages - send a request to petsc-dev at mcs.anl.gov <mailto:petsc-dev at mcs.anl.gov>.
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
> http://www.caam.rice.edu/~mk51/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170526/1542feb6/attachment.html>
