[petsc-dev] Fwd: PETSc blame digest (next) 2017-05-26
Fri May 26 09:04:21 CDT 2017
Does anyone understand this? It seems clear that odm is used.
   Matt
---------- Forwarded message ----------
From: PETSc checkBuilds <petsc-checkbuilds at mcs.anl.gov>
Date: Fri, May 26, 2017 at 9:00 AM
Subject: PETSc blame digest (next) 2017-05-26
To: Matthew Knepley <knepley at gmail.com>, PETSc checkBuilds <
Dear PETSc developer,
This email contains listings of contributions attributed to you by
`git blame` that caused compiler errors or warnings in PETSc automated
testing.  Follow the links to see the full log files. Please attempt to fix
the issues promptly or let us know at petsc-dev at mcs.anl.gov if you are
unable
to resolve the issues.
  The PETSc development team
warnings attributed to commit https://bitbucket.org/petsc/
petsc/commits/a2e1bd4
Plex: Fix adaptation for serial case
  src/dm/impls/plex/plexadapt.c:26
    [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/
2017/05/26/build_next_arch-linux-uni_crush.log]
      /sandbox/petsc/petsc.clone-2/src/dm/impls/plex/plexadapt.c:26:22:
warning: unused variable 'odm' [-Wunused-variable]
2017/05/26/build_next_arch-linux-pkgs-opt_crank.log]
      /sandbox/petsc/petsc.clone/src/dm/impls/plex/plexadapt.c:26:22:
2017/05/26/build_next_arch-linux-gcc-absoft_churn.log]
2017/05/26/build_next_arch-cuda-single_es.log]
2017/05/26/build_next_arch-osx-10.6-cxx-pkgs-opt_ipro.log]
      /Users/petsc/petsc.clone-2/src/dm/impls/plex/plexadapt.c:26:22:
2017/05/26/build_next_arch-linux-pkgs-cxx-mlib_el6.log]
      /sandbox/petsc/petsc.clone-3/src/dm/impls/plex/plexadapt.c:26:22:
2017/05/26/build_next_arch-linux-opt-cxx-quad_grind.log]
2017/05/26/build_next_arch-linux-xsdk-dbg_cg.log]
2017/05/26/build_next_arch-linux-without-fc_cg.log]
2017/05/26/build_next_arch-linux-xsdk-latest_cg.log]
      /sandbox/petsc/petsc.clone-4/src/dm/impls/plex/plexadapt.c:26:22:
2017/05/26/build_next_arch-linux-IPL64_thrash.log]
2017/05/26/build_next_arch-linux-cxx-cmplx-pkgs-64idx_churn.log]
2017/05/26/build_next_arch-linux-dbg-quad_churn.log]
2017/05/26/build_next_arch-linux-pkgs-threadcomm_el6.log]
2017/05/26/build_next_arch-osx-10.6_ipro.log]
      /Users/petsc/petsc.clone/src/dm/impls/plex/plexadapt.c:26:22:
2017/05/26/build_next_arch-freebsd-cxx-pkgs-opt_wii.log]
      /usr/home/balay/petsc.clone-2/src/dm/impls/plex/plexadapt.c:26:22:
2017/05/26/build_next_arch-freebsd-cxx-cmplx-pkgs-dbg_wii.log]
      /usr/home/balay/petsc.clone-3/src/dm/impls/plex/plexadapt.c:26:22:
2017/05/26/build_next_arch-osx-10.6-cxx-cmplx-pkgs-dbg_ipro.log]
      /Users/petsc/petsc.clone-3/src/dm/impls/plex/plexadapt.c:26:22:
2017/05/26/build_next_arch-freebsd-pkgs-opt_wii.log]
      /usr/home/balay/petsc.clone/src/dm/impls/plex/plexadapt.c:26:22:
2017/05/26/build_next_arch-c-exodus-dbg-builder_es.log]
2017/05/26/build_next_arch-linux-pkgs-dbg-ftn-interfaces_crank.log]
2017/05/26/build_next_arch-linux-pkgs-valgrind_el6.log]
2017/05/26/build_next_arch-viennacl_es.log]
2017/05/26/build_next_arch-cuda-double_es.log]
2017/05/26/build_next_arch-osx-xsdk-opt_ipro.log]
      /Users/petsc/petsc.clone-4/src/dm/impls/plex/plexadapt.c:26:22:
2017/05/26/build_next_arch-linux-pkgs-64idx_thrash.log]
2017/05/26/build_next_arch-linux-gcc-ifc-cmplx_crank.log]
To opt-out from receiving these messages - send a request to
petsc-dev at mcs.anl.gov.
experiments lead.
-- Norbert Wiener
http://www.caam.rice.edu/~mk51/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170526/b02636e7/attachment.html>
