[petsc-dev] c++, float128 and complex patch
Michael Gegg michael.gegg at tu-berlin.de
Wed May 3 09:22:27 CDT 2017
Hello Petsc developers,
thank you for providing such a marvellous numerics package, we had/have
a lot of fun using it. For our purposes it was necessary to use Petsc
with c++, float128 and complex. Since this is not possible with the
standard build we made a patch. It uses c style complex numbers as a
workaround.
It can be used with the Parmetis package (there is a little fix in the
interface there) and we have made a Slepc patch that then also allows to
use c++, float128 and complex.
It would be great if you could include it in the petsc software.
We checked the patch for v3.7.6 and v3.7.3 (latest Slepc release)
With best regards,
Michael Gegg
Type: text/x-patch
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170503/220e09d9/attachment.bin>
