[petsc-dev] Can we eliminate support for std::complex?
Jed Brown jed at jedbrown.org
Tue May 2 14:09:49 CDT 2017
Tobin Isaac <tisaac at uchicago.edu> writes:
> On Tue, May 02, 2017 at 09:30:18AM -0500, Matthew Knepley wrote:
>> I have Googled, but I still cannot understand this
>> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/05/02/examples_next_arch-linux-cxx-cmplx-pkgs-64idx_churn.log
>> It appears in another one as well. Does anyone know how to fix this?
>> Otherwise I am turning off ex11 for C++.
>> This is the last problem before merging the Plex tests (modulo jitter in
>> iteration counts on two boxes which I assume we live with until the parser
>> is better).
> I'm changing the unions from PetscScalar to PetscReal right now.  C++
> thinks that std::complex<double> is funky enough that you can't put it
> in a union uninitialized.
Yeah, it isn't a POD type.  Idiotic decision.
I think the union could be eliminated here.  There used to be more
field-agnostic code in this example, but Matt moved most of it to the
library (with the unfortunate consequence that the example can no longer
be used for teaching FV discretization).
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170502/15cdbe92/attachment.sig>
