[petsc-dev] Petsc has generated inconsistent data
Thu Mar 16 19:46:34 CDT 2017
> On Mar 16, 2017, at 10:26 AM, Hong <hzhang at mcs.anl.gov> wrote:
> I fixed typos in maint branch:
> https://bitbucket.org/petsc/petsc/commits/d4ed72bbe47df8d3eb83fd589394594abed431db
> I'll check the error produced by './ex12 -pc_type gasm -ksp_view'.
> Hong
   Pierre and Hong,
     This may not be fixable. In GASM submatrices lie on overlapping collections of MPI processes thus the -mat_view likely won't work because it is called also on these submatrices. Even if it did work I suspect the entries for the various submatrices would be printed out in unreadable random order.
    Are you intentionally trying to see what the submatrices look like?
   Barry
> On Thu, Mar 16, 2017 at 3:31 AM, Pierre Jolivet <pierre.jolivet at enseeiht.fr> wrote:
> Hello,
> Using master:
> > cd $PETSC_DIR/src/ksp/ksp/examples/tutorials && make ex12 && mpirun -np 1 ./ex12 -pc_type gasm -mat_view -ksp_view
> [0]PETSC ERROR: Petsc has generated inconsistent data
> [0]PETSC ERROR: Called more times than PetscViewerASCIIPushSynchronized()
> Also, in mumps.c (cf. http://lists.mcs.anl.gov/pipermail/petsc-dev/2017-February/020440.html):
> “ICNTL(7) (sequentia matrix ordering):” => should be spelled “sequential"
> "ICNTL(8) (scalling strategy):” => should be spelled “scaling”
> "ICNTL(19) (Shur complement info):” => should be spelled “Schur”
> Thanks,
> Pierre
