[petsc-dev] Petsc has generated inconsistent data
Hong hzhang at mcs.anl.gov
Thu Mar 16 10:26:07 CDT 2017
I fixed typos in maint branch:
https://bitbucket.org/petsc/petsc/commits/d4ed72bbe47df8d3eb83fd589394594abed431db
I'll check the error produced by './ex12 -pc_type gasm -ksp_view'.
Hong
On Thu, Mar 16, 2017 at 3:31 AM, Pierre Jolivet <pierre.jolivet at enseeiht.fr>
wrote:
> Hello,
> Using master:
> > cd $PETSC_DIR/src/ksp/ksp/examples/tutorials && make ex12 && mpirun -np
> 1 ./ex12 -pc_type gasm -mat_view -ksp_view
> [0]PETSC ERROR: Petsc has generated inconsistent data
> [0]PETSC ERROR: Called more times than PetscViewerASCIIPushSynchronized()
> Also, in mumps.c (cf. http://lists.mcs.anl.gov/pipermail/petsc-dev/2017-
> February/020440.html):
> “ICNTL(7) (sequentia matrix ordering):” => should be spelled “sequential"
> "ICNTL(8) (scalling strategy):” => should be spelled “scaling”
> "ICNTL(19) (Shur complement info):” => should be spelled “Schur”
> Thanks,
> Pierre
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170316/f7bad9d3/attachment.html>
