[petsc-dev] petsc patch number
Wed Apr 19 10:59:15 CDT 2017
Why do you need to distinguish (between petsc maint snapshots) if you
are using the fixed superlu_dist version with both?
Satish
On Wed, 19 Apr 2017, Kong, Fande wrote:
> Thanks, Satish,
> Yes, but the petsc version is till 3.7.5, right? If so, according to the
> petsc version number,  how can I tell differences between this petsc and
> the old petsc whose version is also 3.7.5.?
> Fande,
> On Wed, Apr 19, 2017 at 9:40 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> > Use --download-superlu_dist=url-to-fixed-superlu_dist-version
> > [or if using superlu_dist from git]
> > --download-superlu_dist-commit=commit
> > Current maint has points to 'v5.1.3' - so you could use:
> > --download-superlu_dist-commit=v5.1.3
> > Satish
> > > Thanks for your email.  Sorry for late reply.
> > > On Thu, Apr 13, 2017 at 10:20 PM, Jed Brown <jed at jedbrown.org> wrote:
> > > > Individual commits are not strictly ordered.  'maint' does not get API
> > > > changes.  What are you trying to test for?  Presence of a bug fix?
> > > Yes, I am going to test for the bug fix.
> > > There is a test system on the moose-side. We usually test all examples
> > > against one or two versions of PETSc, (PETSc-3.7.5 and/or PETSc-3.6.4,
> > > right now). The PETSc is precompiled and sits in the test system.  Now,
> > > there is a bug fix for superlu_dist in the current patched petsc. We want
> > > to test SOME of examples (not all of them) against the current patched
> > > petsc (the version number is still the same, 3.7.5). In a test file, we
> > > have something like "petsc_version= x.x.x " to tell the test system which
> > > version of petsc we want to use.  But now, I can not distinguish the
> > petsc
> > > with the broken superlu_dist and the current patched petsc by using the
> > > petsc version number.
> > > Any suggestions?
> > > Fande,
> > > > "Kong, Fande" <fande.kong at inl.gov> writes:
> > > > > Thanks,
> > > > > In the moose side, we want to make some tests against the current
> > maint,
> > > > > but still have some tests against the old one. The two versions of
> > petsc
> > > > > may have the same petsc version number, e.g. 3.7.5. I want a patch
> > number
> > > > > from which I could tell which one is newer. How it is different from
> > the
> > > > > old one.
> > > > > Any alternative way to do that? When compiling  PETSc, do we have a
> > macro
> > > > > variable to define the commit number?
> > > > > Fande,
> > > > > On Thu, Apr 13, 2017 at 12:06 PM, Satish Balay <balay at mcs.anl.gov>
> > > > wrote:
> > > > >> On Thu, 13 Apr 2017, Kong, Fande wrote:
> > > > >> > Hi Developers,
> > > > >> > Do we increase the patch number when pushing a new patch into
> > maint?
> > > > >> nope
> > > > >> > If not, how to know if the current maint is different from the
> > one I
> > > > >> > just got yesterday. I know a commit number is always available.
> > > > >> git fetch && git log maint..origin/maint
> > > > >> [and you can look at that and decide to do a 'git pull' on maint]
> > > > >> Satish
