[petsc-dev] petsc patch number
Kong, Fande fande.kong at inl.gov
Wed Apr 19 10:57:15 CDT 2017
Thanks, Satish,
Yes, but the petsc version is till 3.7.5, right? If so, according to the
petsc version number,  how can I tell differences between this petsc and
the old petsc whose version is also 3.7.5.?
Fande,
On Wed, Apr 19, 2017 at 9:40 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> Use --download-superlu_dist=url-to-fixed-superlu_dist-version
> [or if using superlu_dist from git]
> --download-superlu_dist-commit=commit
> Current maint has points to 'v5.1.3' - so you could use:
> --download-superlu_dist-commit=v5.1.3
> Satish
> On Wed, 19 Apr 2017, Kong, Fande wrote:
> > Thanks for your email.  Sorry for late reply.
> > On Thu, Apr 13, 2017 at 10:20 PM, Jed Brown <jed at jedbrown.org> wrote:
> > > Individual commits are not strictly ordered.  'maint' does not get API
> > > changes.  What are you trying to test for?  Presence of a bug fix?
> > Yes, I am going to test for the bug fix.
> > There is a test system on the moose-side. We usually test all examples
> > against one or two versions of PETSc, (PETSc-3.7.5 and/or PETSc-3.6.4,
> > right now). The PETSc is precompiled and sits in the test system.  Now,
> > there is a bug fix for superlu_dist in the current patched petsc. We want
> > to test SOME of examples (not all of them) against the current patched
> > petsc (the version number is still the same, 3.7.5). In a test file, we
> > have something like "petsc_version= x.x.x " to tell the test system which
> > version of petsc we want to use.  But now, I can not distinguish the
> petsc
> > with the broken superlu_dist and the current patched petsc by using the
> > petsc version number.
> > Any suggestions?
> > Fande,
> > > "Kong, Fande" <fande.kong at inl.gov> writes:
> > > > Thanks,
> > > > In the moose side, we want to make some tests against the current
> maint,
> > > > but still have some tests against the old one. The two versions of
> petsc
> > > > may have the same petsc version number, e.g. 3.7.5. I want a patch
> number
> > > > from which I could tell which one is newer. How it is different from
> the
> > > > old one.
> > > > Any alternative way to do that? When compiling  PETSc, do we have a
> macro
> > > > variable to define the commit number?
> > > > Fande,
> > > > On Thu, Apr 13, 2017 at 12:06 PM, Satish Balay <balay at mcs.anl.gov>
> > > wrote:
> > > >> On Thu, 13 Apr 2017, Kong, Fande wrote:
> > > >> > Hi Developers,
> > > >> > Do we increase the patch number when pushing a new patch into
> maint?
> > > >> nope
> > > >> > If not, how to know if the current maint is different from the
> one I
> > > >> > just got yesterday. I know a commit number is always available.
> > > >> git fetch && git log maint..origin/maint
> > > >> [and you can look at that and decide to do a 'git pull' on maint]
> > > >> Satish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170419/10fc2460/attachment.html>
