[petsc-dev] next tests, absoft and ifc
Tobin Isaac tisaac at uchicago.edu
Thu Apr 13 20:38:33 CDT 2017
On Thu, Apr 13, 2017 at 04:51:23PM -0600, Scott Kruger wrote:
> This was fixed awhile ago and folded into the altfiles pull request, and
> even at one point had a cherry-picked merge into one of Matt's pull requests
> (it's a single line in config/testparse.py).
There is a different solution to that problem already in next from
a12800a.  I do not think this is the same problem: a problem in a
python script would manifest in all builds on the same machine, but my
problem is limited to specific builds.
At any rate, I'm giving up, accepting that computers are stupid, and
replacing "::ascii_*" with "ascii::ascii_*" so that I don't have to
wait for this to be diagnosed and fixed before cleaning up the nightly
tests.
> I am catching up after some vacation time and don't know the status of the
> altfiles merge.  I thought I had resolved all of the issues Satish raised,
> but it's still open so there must be something...
> Scott
> On 4/13/17 10:29 AM, Tobin Isaac wrote:
> > Hi Satish,
> > I'm working to get all of our dm tests to pass in next.  We have a lot
> > of output that comes from "::ascii_info_detail" being passed to
> > DMViewFromOptions().  On two builds, linux-gcc-absoft_churn and
> > linux-gcc-ifc-cmplx_crank, it looks the viewer format is being ignored
> > and short output is being generated instead.
> > I can't reproduce this behavior on my machine, but I notice that there
> > are no diff errors in the few instances where
> > "ascii::ascii_info_detail" is given instead.
> > Could you please run on those two next builds
> >     PETSC_OPTIONS="-options_view" make -f gmakefile dm_impls_plex_tests-runex5_0
> > to see if somehow keys starting with colons are not being parsed
> > correctly?
> > Thanks,
> >   Toby
> Tech-X Corporation               kruger at txcorp.com
> 5621 Arapahoe Ave, Suite A       Phone: (720) 974-1841
> Boulder, CO 80303                Fax:   (303) 448-7756
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170413/f0ad6c5a/attachment.sig>
