[petsc-dev] next tests, absoft and ifc
Tobin Isaac tisaac at uchicago.edu
Thu Apr 13 11:29:43 CDT 2017
Hi Satish,
I'm working to get all of our dm tests to pass in next.  We have a lot
of output that comes from "::ascii_info_detail" being passed to
DMViewFromOptions().  On two builds, linux-gcc-absoft_churn and
linux-gcc-ifc-cmplx_crank, it looks the viewer format is being ignored
and short output is being generated instead.
I can't reproduce this behavior on my machine, but I notice that there
are no diff errors in the few instances where
"ascii::ascii_info_detail" is given instead.
Could you please run on those two next builds
    PETSC_OPTIONS="-options_view" make -f gmakefile dm_impls_plex_tests-runex5_0
to see if somehow keys starting with colons are not being parsed
correctly?
  Toby
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170413/b18f0340/attachment.sig>
