[petsc-dev] fortran literals
    Barry Smith
    bsmith at mcs.anl.gov
    Thu Sep  1 17:37:08 CDT 2016
> On Sep 1, 2016, at 5:28 PM, Munson, Todd <tmunson at mcs.anl.gov> wrote:
> Which platforms do not define PETSC_USE_FORTRANKIND?
It uses it everywhere the Fortran compiler supports it.
# reverse of the above - but more standard thing to do for F90 compilers
  def checkFortranKind(self):
    '''Checks whether selected_int_kind etc work USE_FORTRANKIND'''
    self.pushLanguage('FC')
    body = '''
        integer(kind=selected_int_kind(10)) i
        real(kind=selected_real_kind(10)) d
    if self.checkCompile('', body):
      self.addDefine('USE_FORTRANKIND', 1)
    self.popLanguage()
    return
  Presumably any Fortran compiler that supports F90 supports it so it is not unreasonable for us to just require it and simplify PETSc in a few places.
>  Are they important
> or can we drop support for them?
> I could probably hack the D or Q for the others, but it would probably
> be ugly.
> Or I could just overrule my OCD today...
> Todd.
>> On Sep 1, 2016, at 5:08 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>> On Sep 1, 2016, at 4:37 PM, Munson, Todd <tmunson at mcs.anl.gov> wrote:
>>> Cool!
>>> For what its worth, that only works when PETSC_USE_FORTRANKIND is true.
>>> I'm not sure how many of the Petsc builds have this flag set.
>> in the other case could you try to tack on the D or Q business?
>> Barry
>>> Any idea how to do the same thing in C?
>>> Todd.
>>>> On Sep 1, 2016, at 4:13 PM, Lisandro Dalcin <dalcinl at gmail.com> wrote:
>>>> On 1 September 2016 at 23:05, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>> I didn't have a solution to this
>>>> ! These lines should be added to $PETSC_DIR/include/petsc/finclude/petscsysdef.h
>>>> #if defined(PETSC_USE_REAL_SINGLE)
>>>> integer, parameter :: PETSC_REAL_KIND = selected_real_kind(5)
>>>> #elif defined(PETSC_USE_REAL_DOUBLE)
>>>> integer, parameter :: PETSC_REAL_KIND = selected_real_kind(10)
>>>> #elif defined(PETSC_USE_REAL___FLOAT128)
>>>> integer, parameter :: PETSC_REAL_KIND = selected_real_kind(20)
>>>> #endif
>>>> ! User code should write literals this way
>>>> PetscReal x
>>>> x = 0.123456789123456789123456789_PETSC_REAL_KIND
>>>> Lisandro Dalcin
>>>> Research Scientist
>>>> Computer, Electrical and Mathematical Sciences & Engineering (CEMSE)
>>>> Extreme Computing Research Center (ECRC)
>>>> King Abdullah University of Science and Technology (KAUST)
>>>> http://ecrc.kaust.edu.sa/
>>>> 4700 King Abdullah University of Science and Technology
>>>> al-Khawarizmi Bldg (Bldg 1), Office # 0109
>>>> Thuwal 23955-6900, Kingdom of Saudi Arabia
>>>> http://www.kaust.edu.sa
>>>> Office Phone: +966 12 808-0459
