[petsc-dev] fortran literals
Thu Sep 1 17:08:41 CDT 2016
> On Sep 1, 2016, at 4:37 PM, Munson, Todd <tmunson at mcs.anl.gov> wrote:
> Cool!
> For what its worth, that only works when PETSC_USE_FORTRANKIND is true.
> I'm not sure how many of the Petsc builds have this flag set.
  in the other case could you try to tack on the D or Q business?
 Barry
> Any idea how to do the same thing in C?
> Todd.
>> On Sep 1, 2016, at 4:13 PM, Lisandro Dalcin <dalcinl at gmail.com> wrote:
>> On 1 September 2016 at 23:05, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>   I didn't have a solution to this
>> ! These lines should be added to $PETSC_DIR/include/petsc/finclude/petscsysdef.h
>> #if defined(PETSC_USE_REAL_SINGLE)
>> integer, parameter :: PETSC_REAL_KIND = selected_real_kind(5)
>> #elif defined(PETSC_USE_REAL_DOUBLE)
>> integer, parameter :: PETSC_REAL_KIND = selected_real_kind(10)
>> #elif defined(PETSC_USE_REAL___FLOAT128)
>> integer, parameter :: PETSC_REAL_KIND = selected_real_kind(20)
>> #endif
>> ! User code should write literals this way
>> PetscReal x
>> x = 0.123456789123456789123456789_PETSC_REAL_KIND
>> Lisandro Dalcin
>> Research Scientist
>> Computer, Electrical and Mathematical Sciences & Engineering (CEMSE)
>> Extreme Computing Research Center (ECRC)
>> King Abdullah University of Science and Technology (KAUST)
>> http://ecrc.kaust.edu.sa/
>> 4700 King Abdullah University of Science and Technology
>> al-Khawarizmi Bldg (Bldg 1), Office # 0109
>> Thuwal 23955-6900, Kingdom of Saudi Arabia
>> http://www.kaust.edu.sa
>> Office Phone: +966 12 808-0459
