[petsc-dev] Possible error running C/C++ src/snes/examples/tutorials/ex19 with 1 MPI process
Mon Oct 10 17:00:49 CDT 2016
On Mon, 10 Oct 2016, Satish Balay wrote:
> Removing superlu_fixed the previous error? Thats wierd..
> You can try the attached patch - and see if that fixes this valgrind issue..
you can replace the previous progname.patch with the following two.. [these should be in the next patch update]
https://bitbucket.org/petsc/petsc/commits/1a5f81e5a142bc6fde36c3a51c072ace33ca0cf8
https://bitbucket.org/petsc/petsc/commits/9350f85d4de3048e6e39df431416aa18087af8b6
Satish
