[petsc-dev] Possible error running C/C++ src/snes/examples/tutorials/ex19 with 1 MPI process
Antonio Trande anto.trande at gmail.com
Sun Oct 9 13:39:52 CDT 2016
On 10/09/2016 05:39 PM, Satish Balay wrote:
> Perhaps chkopts also doesn't make sense anymore [esp with user
> makefiles] - so you could use the attached patch [which diables
> checkopts - and this also disables petscnagupgrade.py]
Thank you for the patch.
I see error during testing of OpenMPI libs (papi support is disabled):
https://paste.fedoraproject.org/447193/
Full log:
https://copr-be.cloud.fedoraproject.org/results/sagitter/petsc/fedora-rawhide-x86_64/00462818-petsc/build.log.gz
Antonio Trande
mailto: sagitter 'at' fedoraproject 'dot' org
http://fedoraos.wordpress.com/
https://fedoraproject.org/wiki/User:Sagitter
GPG Key: 0x6CE6D08A
Check on https://keys.fedoraproject.org/
Desc: OpenPGP digital signature
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20161009/7d1d7427/attachment.sig>
