[petsc-dev] Possible error running C/C++ src/snes/examples/tutorials/ex19 with 1 MPI process
Sat Oct 8 16:30:18 CDT 2016
On Sat, 8 Oct 2016, Antonio Trande wrote:
> >> On 10/08/2016 05:57 PM, Antonio Trande wrote:
> >>> This is a rebuild of OpenBlas outside Fedora repositories, so they're
> >>> unofficial packages; i have included optimization flags +
> >>> '-fdefault-integer-8' for 64bit-int libs:
> >>> Fedora 24 packages:
> >>> https://copr-be.cloud.fedoraproject.org/results/sagitter/petsc/fedora-24-x86_64/00462441-openblas/
> >>> Build log:
> >>> https://copr-be.cloud.fedoraproject.org/results/sagitter/petsc/fedora-24-x86_64/00462441-openblas/build.log.gz
> >>> Then, i have rebuilt Petsc by linking against unofficial recompiled
> >>> Openblas libs; build log:
> >>> https://copr-be.cloud.fedoraproject.org/results/sagitter/petsc/fedora-24-x86_64/00462470-petsc/build.log.gz
> >>> Extracted section about testing: https://paste.fedoraproject.org/446212/
> >>> PS.
> >>> Does not appear any error if running 'make test' on my PC.
> >> This is the log from a debugging build:
> >> https://copr-be.cloud.fedoraproject.org/results/sagitter/petsc/fedora-rawhide-x86_64/00462512-petsc/build.log.gz
> > Previously you had a build where these errors didn't come up
> > https://paste.fedoraproject.org/445643/
> I seen that 'csh' tool was not found.
Not sure what you mean. I don't see any 'csh' in either of the logs.
> > But now the build gives errors.
> > Running test examples to verify correct installation
> > Using PETSC_DIR=/builddir/build/BUILD/petsc-3.7.3/petsc-3.7.3 and PETSC_ARCH=x86_64
> > See http://www.mcs.anl.gov/petsc/documentation/faq.html
> > [0]PETSC ERROR: #1 PetscLogInitialize() line 219 in /builddir/build/BUILD/petsc-3.7.3/petsc-3.7.3/src/sys/logging/plog.c
> > [0]PETSC ERROR: #2 PetscInitialize() line 891 in /builddir/build/BUILD/petsc-3.7.3/petsc-3.7.3/src/sys/objects/pinit.c
> > Possible error running C/C++ src/snes/examples/tutorials/ex19 with 2 MPI processes
> > Looks like we discussed this issue before:
> > http://lists.mcs.anl.gov/pipermail/petsc-users/2016-June/029634.html
> > The key is to make sure the correct petsc.so and petscconf.h are used
> > in the test [with the way this build is being done, and stuff getting
> > copied arround - the makefiles that do 'make test' might have invalid
> > info..]
> > Perhaps you can rerun this via valgraind again to see what it says.
> > Satish
> I dont see any line related to openblas now.
In the valgrind output? What lines do you see?
Its crashing in PetscInitialize() - i.e its crashing at the very begining - and didn't get to the blas calls.
[and this somehow worked in  https://paste.fedoraproject.org/445643/ - so I don't really understand
whats going on...]
Satish
