[petsc-dev] Possible error running C/C++ src/snes/examples/tutorials/ex19 with 1 MPI process
Antonio Trande anto.trande at gmail.com
Sat Oct 8 14:00:28 CDT 2016
On 10/08/2016 05:57 PM, Antonio Trande wrote:
> This is a rebuild of OpenBlas outside Fedora repositories, so they're
> unofficial packages; i have included optimization flags +
> '-fdefault-integer-8' for 64bit-int libs:
> Fedora 24 packages:
> https://copr-be.cloud.fedoraproject.org/results/sagitter/petsc/fedora-24-x86_64/00462441-openblas/
> Build log:
> https://copr-be.cloud.fedoraproject.org/results/sagitter/petsc/fedora-24-x86_64/00462441-openblas/build.log.gz
> Then, i have rebuilt Petsc by linking against unofficial recompiled
> Openblas libs; build log:
> https://copr-be.cloud.fedoraproject.org/results/sagitter/petsc/fedora-24-x86_64/00462470-petsc/build.log.gz
> Extracted section about testing: https://paste.fedoraproject.org/446212/
> PS.
> Does not appear any error if running 'make test' on my PC.
This is the log from a debugging build:
https://copr-be.cloud.fedoraproject.org/results/sagitter/petsc/fedora-rawhide-x86_64/00462512-petsc/build.log.gz
Antonio Trande
mailto: sagitter 'at' fedoraproject 'dot' org
http://fedoraos.wordpress.com/
https://fedoraproject.org/wiki/User:Sagitter
GPG Key: 0x6CE6D08A
Check on https://keys.fedoraproject.org/
Desc: OpenPGP digital signature
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20161008/0731bf51/attachment.sig>
