[petsc-dev] Possible error running C/C++ src/snes/examples/tutorials/ex19 with 1 MPI process
Antonio Trande anto.trande at gmail.com
Sat Oct 8 10:57:51 CDT 2016
This is a rebuild of OpenBlas outside Fedora repositories, so they're
unofficial packages; i have included optimization flags +
'-fdefault-integer-8' for 64bit-int libs:
Fedora 24 packages:
https://copr-be.cloud.fedoraproject.org/results/sagitter/petsc/fedora-24-x86_64/00462441-openblas/
Build log:
https://copr-be.cloud.fedoraproject.org/results/sagitter/petsc/fedora-24-x86_64/00462441-openblas/build.log.gz
Then, i have rebuilt Petsc by linking against unofficial recompiled
Openblas libs; build log:
https://copr-be.cloud.fedoraproject.org/results/sagitter/petsc/fedora-24-x86_64/00462470-petsc/build.log.gz
Extracted section about testing: https://paste.fedoraproject.org/446212/
PS.
Does not appear any error if running 'make test' on my PC.
Antonio Trande
mailto: sagitter 'at' fedoraproject 'dot' org
http://fedoraos.wordpress.com/
https://fedoraproject.org/wiki/User:Sagitter
GPG Key: 0x6CE6D08A
Check on https://keys.fedoraproject.org/
Desc: OpenPGP digital signature
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20161008/29451992/attachment.sig>
