[petsc-dev] Setup subsnes in nasm.c
Lulu Liu lulu.liu at kaust.edu.sa
Sun May 29 13:43:39 CDT 2016
On Fri, May 27, 2016 at 5:50 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, May 27, 2016 at 10:39 AM, Lulu Liu <lulu.liu at kaust.edu.sa> wrote:
>> I am trying to solve a nonlinear problem using NASM, and see the code in
>>  petsc/src/snes/impls/nasm/nasm.c. However, I feel confused about how
>> subsnes for each subdomain gets its own function, and I can not find
>> anything like SNESSetFunction(subsnes,......). Could you show me which line
>> subsnes gets its own function in nasm.c?
> The function is coming from the DM. The subDMs get the same SNESDM
> structures as the original DM, and then
> SNESSetDM() is called on them.
>> In addition, I would like to set up something using
>> SNESNASMSetSubdomains_NASM (). Is there any example showing how to set
>> subsnes, iscatter, oscatter,gscatter? Thanks!
> Unfortunately there are no examples. I am not a big fan of this interface
> which is only really intelligible for Cartesian grids.
> I am going to try and rework it this fall.
Does the current interface (nasm.c) work for unstructured grids?
>   Thanks,
>      Matt
>> PetscErrorCode SNESNASMSetSubdomains_NASM(SNES snes,PetscInt n,SNES
>> subsnes[],VecScatter iscatter[],VecScatter oscatter[],VecScatter gscatter[])
>> This message and its contents, including attachments are intended solely
>> for the original recipient. If you are not the intended recipient or have
>> received this message in error, please notify me immediately and delete
>> this message from your computer system. Any unauthorized use or
>> distribution is prohibited. Please consider the environment before printing
>> this email.
> experiments lead.
> -- Norbert Wiener
this email.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160529/d989a606/attachment.html>
