[petsc-dev] strangness in Chebyshev estimate of eigenvalues
Mark Adams mfadams at lbl.gov
Fri May 27 12:33:45 CDT 2016
OK, I squashed, fixed the push line (and also did --global pull.ff only),
and pushed.
On Fri, May 27, 2016 at 9:07 AM, Jed Brown <jed at jedbrown.org> wrote:
> Mark Adams <mfadams at lbl.gov> writes:
> >> Satish, please don't use this syntax for force pushes.  Prefer
> >>  git push origin +mark/snes-ex65c
> > 08:13 mark/snes-ex56c<> ~/Codes/petsc$ git push origin +mark/snes-ex65c
> > error: src refspec mark/snes-ex65c does not match any.
> > error: failed to push some refs to 'git at bitbucket.org:petsc/petsc.git'
> Dyslexia in my instructions -- ex65 should be ex56.  The point is that
> +branch syntax says to only force push a single branch while "git push
> --force" can apply to other branches depending on git config/version.
> > FYI, I then tried to pull (again) to remove this "<":
> > 08:16 1 mark/snes-ex56c<> ~/Codes/petsc$ git pull origin mark/snes-ex56c
> > From bitbucket.org:petsc/petsc
> >  * branch            mark/snes-ex56c -> FETCH_HEAD
> > Merge made by the 'recursive' strategy.
> You need to get rid of this merge.  In fact, I think that in your role
> using Git, you don't ever want automatic merges of this sort, so run
>   git config --global pull.ff only
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160527/50c2d261/attachment.html>
