[petsc-dev] strangness in Chebyshev estimate of eigenvalues
Fri May 27 10:54:24 CDT 2016
On Fri, 27 May 2016, Satish Balay wrote:
> On Fri, 27 May 2016, Mark Adams wrote:
> > > Satish, please don't use this syntax for force pushes.  Prefer
> > >  git push origin +mark/snes-ex65c
> > 08:13 mark/snes-ex56c<> ~/Codes/petsc$ git push origin +mark/snes-ex65c
> > error: src refspec mark/snes-ex65c does not match any.
> > error: failed to push some refs to 'git at bitbucket.org:petsc/petsc.git'
> I have no idea why you got this error.
I suspect - for some reason t- he 'upstream' reference for this branch
is not set.  I think the following would have worked in this case.
git push -u origin +mark/snes-ex65c
Satish
