[petsc-dev] strangness in Chebyshev estimate of eigenvalues
Jed Brown jed at jedbrown.org
Wed May 25 10:00:59 CDT 2016
Mark Adams <mfadams at lbl.gov> writes:
> FYI, I get this error from rebasing. I will look into what they suggest.
What command did you use to rebase?
I ran "git rebase master" and fixed one trivial conflict in a makefile.
The result is in 'jed/mark/snes-ex56c' if you want to check it out.
> warning: squelched 32 whitespace errors
> warning: 37 lines add whitespace errors.
> Falling back to patching base and 3-way merge...
> Auto-merging config/builder.py
> CONFLICT (content): Merge conflict in config/builder.py
> error: Failed to merge in the changes.
> Patch failed at 0029 Adding tests for dmplex adaptation
> The copy of the patch that failed is found in: .git/rebase-apply/patch
> When you have resolved this problem, run "git rebase --continue".
> If you prefer to skip this patch, run "git rebase --skip" instead.
> To check out the original branch and stop rebasing, run "git rebase
> --abort".
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160525/a7fcbf0d/attachment.sig>
