[petsc-dev] strangness in Chebyshev estimate of eigenvalues
Tue May 24 21:57:00 CDT 2016
On Tue, 24 May 2016, Mark Adams wrote:
> There are a lot of diffs like this. What make you think it is mine?  The
> cheby changes should not create such a large diff.
Your pull request https://bitbucket.org/petsc/petsc/pull-requests/479/mark-snes-ex56c/diff#chg-src/ksp/ksp/examples/tests/output/ex26_1.out
shows similar diffs - i.e your changes.
But then - as mentioned below - this branch is not yet completely
merged to next - and next is breaking with the same diffs.
So I found the diff was coming from 7fd3bd7 - which was directly
commited to next [again a no-no wrt workflow].
When  I looked at the commit - you are listed as the author..
https://bitbucket.org/petsc/petsc/commits/7fd3bd7
Satish
