[petsc-dev] strangness in Chebyshev estimate of eigenvalues
Mark Adams mfadams at lbl.gov
Tue May 24 19:01:10 CDT 2016
On Tue, May 24, 2016 at 2:53 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Tue, 24 May 2016, Mark Adams wrote:
> > Do I now wait for my pull request to be approved?
> Mark,
> Currently there is a bit of mess in regards to your branches.
Yes. This got messy because I was building on Matt's work.  mark/snes-ex56c
super seeds everything else.
I used cherry-pick to duplicate commits in next. This may explain the
missing merges.
I checked Barry's commits and saw the mark/snes-ex56b and picked it in
mark/snes-ex56c.
I will clean up these old ex56's
Let me know if I missed anything below.
> $ git branch -r |grep mark |grep ex56
>   origin/mark/ksp-ex56
>   origin/mark/ksp-newex56
>   origin/mark/snes-ex56b
>   origin/mark/snes-ex56c
> You have a bunch of branches with the name 'ex56' - presumably you
> worked initially on mark/snes-ex56b and switched to 'mark/snes-ex56c'.
> And I see the the following 2 merges to next
> commit e223b1660d8274c4632642ec520eee8c34d18eb5
> Merge: de2cc15 c13d8fd
> Author: Barry Smith <bsmith at mcs.anl.gov>
> Date:   Mon May 23 15:27:49 2016 -0500
>     Merge branch 'mark/snes-ex56b' into next
> commit ebff70bc705bbe7fea86844e10d9a274abdf3658
> Merge: c8d3fd4 dfc6d4a
> Author: Satish Balay <balay at mcs.anl.gov>
> Date:   Thu May 19 23:59:01 2016 -0500
>     Merge branch 'mark/snes-ex56c' into next
> On my part - I noticed you had a buggy commit in next - which I wanted
> to fix - so fixed in 'mark/snes-ex56c' and merged to next.
> $ git branch -r --contains eb041292
>   origin/next
> But how did this commit come to next? I don't see a prior 'Merge
> branch 'mark/snes-ex56c' message in next history. Ok I think
> c8d3fd49b4313a86346f23ef7d5371efba2d3dc9 was the next HEAD - when I
> did the merge.
> $ git log --oneline --merges --ancestry-path
> eb041292..c8d3fd49b4313a86346f23ef7d5371efba2d3dc9
> c8d3fd4 Merge branch 'next' of bitbucket.org:petsc/petsc into next
> 01528be Merge branch 'master' into next
> 8bd3767 Merge branch
> 'pr476/psanan/psanan/pc-telescope-subcomm-type/master' into next
> 83661ee Merge branch
> 2a9b9f0 Merge branch 'master' into next
> d5742a2 fixed error check in main of ex56
> a003960 Merge branch 'master' of bitbucket.org:petsc/petsc into
> mark/snes-ex56c
> So 'd5742a2 fixed error check in main of ex56' is a merge commit?
> You did code change and merge in the same commit - and removed the
> default git commit message - "Merge 'mark/snes-ex56c' into next"?
> This is way confusing..
> Now to figure out how to fix this. I see origin/mark/snes-ex56b is
> merged to next - but origin/mark/snes-ex56c is not completely merged.
> Is origin/mark/snes-ex56b abandoned? If so - I should revert Barry's
> inadvertent merge of origin/mark/snes-ex56b into next - and merge
> Thanks,
> Satish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160524/06950f59/attachment.html>
