[petsc-dev] strangness in Chebyshev estimate of eigenvalues
Tue May 24 17:23:47 CDT 2016
Another issue:
http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2016/05/24/examples_next_arch-cuda-double_es.log
/scratch/petsc/petsc.clone/src/ksp/ksp/examples/tests
Possible problem with ex26_1, diffs above
balay at asterix /home/balay/petsc (next=)
$ git diff master..next -- src/ksp/ksp/examples/tests/output/ex26_1.out |cat
diff --git a/src/ksp/ksp/examples/tests/output/ex26_1.out b/src/ksp/ksp/examples/tests/output/ex26_1.out
index c46eca6..659624f 100644
--- a/src/ksp/ksp/examples/tests/output/ex26_1.out
+++ b/src/ksp/ksp/examples/tests/output/ex26_1.out
@@ -1,10 +1,6 @@
 Fine grid size 9 by 9
-  0 KSP Residual norm 10.0656
-  1 KSP Residual norm 4.35349
-  2 KSP Residual norm 0.638099
-  3 KSP Residual norm 0.0815887
-  4 KSP Residual norm 0.00953547
-  5 KSP Residual norm 0.00117851
-  6 KSP Residual norm 0.000265924
-  7 KSP Residual norm 2.74224e-05
-Number of iterations = 7
+  0 KSP Residual norm 23.5347
+  1 KSP Residual norm 0.230059
+  2 KSP Residual norm 0.000468129
+  3 KSP Residual norm 1.16147e-06
+Number of iterations = 3
$ git log --oneline src/ksp/ksp/examples/tests/output/ex26_1.out  |head -1
7fd3bd7 updated test for new cheby
$ git branch -r --contains 7fd3bd7
  origin/next
So you made this change directly to next? Looks like next is way
corrupted - and I should just rewind it to latest master..
Satish
On Tue, 24 May 2016, Satish Balay wrote:
> On Tue, 24 May 2016, Mark Adams wrote:
> > Do I now wait for my pull request to be approved?
> Mark,
> Currently there is a bit of mess in regards to your branches.
> $ git branch -r |grep mark |grep ex56
>   origin/mark/ksp-ex56
>   origin/mark/ksp-newex56
>   origin/mark/snes-ex56b
>   origin/mark/snes-ex56c
> You have a bunch of branches with the name 'ex56' - presumably you
> worked initially on mark/snes-ex56b and switched to 'mark/snes-ex56c'.
> And I see the the following 2 merges to next
> commit e223b1660d8274c4632642ec520eee8c34d18eb5
> Merge: de2cc15 c13d8fd
> Author: Barry Smith <bsmith at mcs.anl.gov>
> Date:   Mon May 23 15:27:49 2016 -0500
>     Merge branch 'mark/snes-ex56b' into next
> commit ebff70bc705bbe7fea86844e10d9a274abdf3658
> Merge: c8d3fd4 dfc6d4a
> Author: Satish Balay <balay at mcs.anl.gov>
> Date:   Thu May 19 23:59:01 2016 -0500
>     Merge branch 'mark/snes-ex56c' into next
> On my part - I noticed you had a buggy commit in next - which I wanted
> to fix - so fixed in 'mark/snes-ex56c' and merged to next.
> $ git branch -r --contains eb041292
>   origin/next
> But how did this commit come to next? I don't see a prior 'Merge
> branch 'mark/snes-ex56c' message in next history. Ok I think
> c8d3fd49b4313a86346f23ef7d5371efba2d3dc9 was the next HEAD - when I
> did the merge.
> $ git log --oneline --merges --ancestry-path eb041292..c8d3fd49b4313a86346f23ef7d5371efba2d3dc9
> c8d3fd4 Merge branch 'next' of bitbucket.org:petsc/petsc into next
> 01528be Merge branch 'master' into next
> 8bd3767 Merge branch 'pr476/psanan/psanan/pc-telescope-subcomm-type/master' into next
> 83661ee Merge branch 'pr476/psanan/psanan/pc-telescope-subcomm-type/master' into next
> 2a9b9f0 Merge branch 'master' into next
> d5742a2 fixed error check in main of ex56
> a003960 Merge branch 'master' of bitbucket.org:petsc/petsc into mark/snes-ex56c
> So 'd5742a2 fixed error check in main of ex56' is a merge commit?
> You did code change and merge in the same commit - and removed the
> default git commit message - "Merge 'mark/snes-ex56c' into next"?
> This is way confusing..
> Now to figure out how to fix this. I see origin/mark/snes-ex56b is
> merged to next - but origin/mark/snes-ex56c is not completely merged.
> Is origin/mark/snes-ex56b abandoned? If so - I should revert Barry's
> inadvertent merge of origin/mark/snes-ex56b into next - and merge
> Thanks,
> Satish
