[petsc-dev] strangness in Chebyshev estimate of eigenvalues
Tue May 24 16:53:17 CDT 2016
On Tue, 24 May 2016, Mark Adams wrote:
> Do I now wait for my pull request to be approved?
Mark,
Currently there is a bit of mess in regards to your branches.
$ git branch -r |grep mark |grep ex56
  origin/mark/ksp-ex56
  origin/mark/ksp-newex56
  origin/mark/snes-ex56b
  origin/mark/snes-ex56c
You have a bunch of branches with the name 'ex56' - presumably you
worked initially on mark/snes-ex56b and switched to 'mark/snes-ex56c'.
And I see the the following 2 merges to next
commit e223b1660d8274c4632642ec520eee8c34d18eb5
Merge: de2cc15 c13d8fd
Author: Barry Smith <bsmith at mcs.anl.gov>
Date:   Mon May 23 15:27:49 2016 -0500
    Merge branch 'mark/snes-ex56b' into next
commit ebff70bc705bbe7fea86844e10d9a274abdf3658
Merge: c8d3fd4 dfc6d4a
Author: Satish Balay <balay at mcs.anl.gov>
Date:   Thu May 19 23:59:01 2016 -0500
    Merge branch 'mark/snes-ex56c' into next
On my part - I noticed you had a buggy commit in next - which I wanted
to fix - so fixed in 'mark/snes-ex56c' and merged to next.
$ git branch -r --contains eb041292
  origin/next
But how did this commit come to next? I don't see a prior 'Merge
branch 'mark/snes-ex56c' message in next history. Ok I think
c8d3fd49b4313a86346f23ef7d5371efba2d3dc9 was the next HEAD - when I
did the merge.
$ git log --oneline --merges --ancestry-path eb041292..c8d3fd49b4313a86346f23ef7d5371efba2d3dc9
c8d3fd4 Merge branch 'next' of bitbucket.org:petsc/petsc into next
01528be Merge branch 'master' into next
8bd3767 Merge branch 'pr476/psanan/psanan/pc-telescope-subcomm-type/master' into next
83661ee Merge branch 'pr476/psanan/psanan/pc-telescope-subcomm-type/master' into next
2a9b9f0 Merge branch 'master' into next
d5742a2 fixed error check in main of ex56
a003960 Merge branch 'master' of bitbucket.org:petsc/petsc into mark/snes-ex56c
So 'd5742a2 fixed error check in main of ex56' is a merge commit?
You did code change and merge in the same commit - and removed the
default git commit message - "Merge 'mark/snes-ex56c' into next"?
This is way confusing..
Now to figure out how to fix this. I see origin/mark/snes-ex56b is
merged to next - but origin/mark/snes-ex56c is not completely merged.
Is origin/mark/snes-ex56b abandoned? If so - I should revert Barry's
inadvertent merge of origin/mark/snes-ex56b into next - and merge
Satish
