[petsc-dev] strangness in Chebyshev estimate of eigenvalues
Mark Adams mfadams at lbl.gov
Tue May 24 16:25:08 CDT 2016
On Tue, May 24, 2016 at 2:20 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> Well 'git merge master' on this branch doesn't help with this concern.
> The process is
> - don't merge to next until feature complete
> [in this stage - you can rebase against master as many times as necessary]
> - on feature completion - merge to next
> - and monitor 'next' tests dashboard -
How does that work?  I have been getting messages sometimes.  Are these
sufficient or should I check a web page? (URL?)
> until all related issues are
>  resolved and then merge to master [this next testing should be
>  resolved in a few days - not weeks]
OK, a few days.  I was not sure about the time scale. So not every night.
> - [you can run a local test to make sure this is working before you
>  push]
> - and if issues come up in 'master' tests on dashboard - fix in
>  feature branch - and merge to master.
> Satish
> On Tue, 24 May 2016, Mark Adams wrote:
> > OK, so you just trust that working in next is proof that it will work in
> > master and just 'git merge branch' in master without ever doing a  'git
> > merge master' in branch.
> > Do I now wait for my pull request to be approved?
> > On Tue, May 24, 2016 at 12:12 AM, Jed Brown <jed at jedbrown.org> wrote:
> > > Mark Adams <mfadams at lbl.gov> writes:
> > > > I am merging master more than I need to, just to be up to date.  I
> guess
> > > it
> > > > pollutes the history with all these merges.  And I should squash
> them...
> > > You shouldn't merge from 'master' unless you need something specific,
> > > and in that case, write a commit message explaining what it is that you
> > > need.  You can rebase at will (before publishing your branch), but it's
> > > generally fine to just work in your branch and ignore what is happening
> > > in other branches.
> > > The rationale is explained in detail at the links in this section.
> https://bitbucket.org/petsc/petsc/wiki/developer-instructions-git#markdown-header-merging
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160524/d92b136e/attachment.html>
